Sleeve SPUN?!?!*Pics Added*
napphappy
Post by napphappy »
So I tore into a EJ22t that I bought for parts. The seller said it had been overheated. Had no idea what to expect.
I get the left side front wrist pin accses plug out and :shock: the iron sleeve has rotated so that it is mostly blocking the hole.
I have pics I will post later.
Has anyone ever seen or heard of this before?
Also part of the block deck on #3 had melted away.
That's uh ... not good.
I'd say that overheated a little bit.
dzx
Post by dzx »
I've never heard of that happening.
///M
'93 Legacy SS - part out
Sounds like that block is toast.
scuzzy
Post by scuzzy »
I had the return hose from my IAC break off the coolant return to the radiator and spew coolant out of my engine (took it awhile to run low, took me awhile to notice it)
the block got hot (I drove it till it approached Hot, then stopped) but I can't imagine what kind of heat that thing suffered.
#82 M4 TRSCCA Rallycross
dzx
Post by dzx »
I overheated my block a couple times due to a shitty connection in the radiator fans before i figured out what was wrong. Then my radiator blew the end tanks off.
I haven't had any problems with it though, and that was about 5 months ago. knock on wood...
///M
