Hey guys,
There's a constant scraping/grinding sound combined with an occasional BANG sound from the area of the driver's front wheel. The scraping goes with wheel speed, not engine speed, definitely a wheel or drivetrain issue. It makes all the noises even at a crawling pace.
Now get this - If I lean out the window while the car crawls along, I can SEE the driver's side wheel SHAKES each time there's a bang sound and the car actually felt like it was being slightly held back. This was bad enough that I thought I couldn't make it a few blocks before something in the wheel or drivetrain nuked.
It started when I got an alignment. It was done by a really good shop, and we haven't found anything caused by their work so far, so the problem could be unrelated. I just throw that in there as clue. Left the shop with the car sounding fine and drove 45 minutes at highway speeds. It wasn't until I slowed down to city street speeds that I noticed the racket.
Debugging on the side of a street in downtown Baltimore:
* Wheel is not rubbing on anything - nothing is even close (caliper, strut, fender, knuckle, etc)
* Lugnuts were tight. I even took wheels off, re-torqued them, and the car still made the racket
* Wheel bearings seemed ok. I shoved the wheels and no loose movement. Also this is a clue that the alignment bolts are not loose either.
* All bolts used during the alignment were still tight... at least with a hand wrench
* No lost tools found in engine compartment
* A different garage did a full inspection of the drivetrain and didn't find anything wrong with it either.
* The only thing that we've found wrong was that the alignment tech forgot to clip the front passenger ABS wheel speed sensor under the camber nut, so the wire was dangling loose. But, note that was not the wheel that had problems.
* I am getting an ABS light now, presumably due to abuse of the wheel speed sensor cable.
THE KICKER:
I had the car towed to a garage around the corner, and it made the noises as we pulled off the flatbed, but then after sitting still for a a couple hours, THE CAR WAS FINE! No noise or anything. He did a full inspection of the drivetrain on a lift, ran it on the lift, and road tests, and found no problems other than the wheel speed sensor wire. And this is a completely different garage, so he's got every incentive to find fault with the first garage
Oh man, it's great that the car is not making the noise now, but how long will that situation last??? I can't drive hours away from home this weekend with this sort of unsolved mystery!
