Stock AWIC Information
Front, Top, Air, Water.
THAWA
Post by THAWA »
I didn't see this info anywhere during a search, so if it's already posted somewhere I'll delete this thread. This is from a 92 FSM
Intercooler
Style: Drain cup
Core size: 270 x 128 x 70 mm = 2,419,200 mm³
Core cooling capacity: 3,400 kcal/h
Radiator
Style: Tube/fin
Core size: 400 x 247.5 x 32 mm = 3,168,000 mm³
Core cooling capacity: 4.650 kcal/h
Water pump
Flow rate: 15 l/m
Head: 2 mAq
Power consumption: Low 28W, High 50W
Total capacity
Coolant: 1.9 l
Can anybody explain what a Drain Cup style of radiator is?
Also, the change over point of the water pump is based on the TPS, when it's more than 80% it goes to high speed.
I thought I posted that info, but I can't seem to find it.
Here's all the AWIC data pdf'd
http://www.main.experiencetherave.com:8 ... c_data.zip
