Gear Ratio and LSD info
DLC
Post by DLC »
From Stimpy's thread:
Unless specified, the LSD uses male axles and is a viscous coupling unit.
Impreza:
2000-2001 2.5RS 5MT, 4.111
2000-2001 2.5RS 4EAT, 4.444
2002+ WRX 5MT, 3.545,
2002+ WRX 4EAT, 4.111
2004 WRX STi 6MT, 3.900, mechanical
SVX:
1992-1997 AWD 4EAT, 3.545 final drive, has axle stubs
Legacy:
1991-1992 Turbo 5MT (Sedan only?), 3.900 final drive, has axle stubs
2000 GT, GT-LTD, Outback-CW, Outback-LTD, Outback-SDN (excluding Outback, Brighton, and L)
2001+ 2.5L (Excluding Brighton and L) 5MT, 4.111
2001+ 2.5L (Excluding Brighton and L) 4EAT, 4.444
2002+ 3.0L (H6) Outback and Outback-SDN 5MT, 4.111
2003+ Baja, see Legacy specifications
Forester
2000-2002 Forester S 5MT, 4.111
2000-2002 Forester S 4EAT, 4.444
2003+ with Disc Brakes 5MT, 4.111
2003+ with Disc Brakes 4EAT, 4.444
2004 XT Turbo 5MT and 4EAT, 4.444
-- Make sure you read the thread for updated info --
Legacy Central
This page has a lot of info: http://kmhafer.datsun510.com/Subaru.htm
Project_Legacy
Post by Project_Legacy »
hey this is great info! thanks!
00 5MT AWD 2.5 RS - New Project
napphappy
Post by napphappy »
Well ths is interesting:
"I did just this by purchasing a used Subaru 3.70 LSD unit and a used legacy 4.11 open R-160 differential and creating a 4.11 LSD unit from the parts. I paid a rear-end shop $120 to drill the six 10mm holes out to 11mm so the LSD unit's bolts could be used, and to set up the newly assembled unit with the correct tolerances."
So it is possible to convert a non-LSD to LSD.
I may have to try this.
Subtle
Post by Subtle »
93 Legacy Turbo Wagon has 3.9 final drive ratios.
In the drivers manual.
bmxkelowna
Post by bmxkelowna »
what is the ratio on the 98 legacy 5mt? and also the 96 5mt?
98 Legacy GT 5mt is 4.111
bmxkelowna
was there any 3.9 5mt rear ends in 98?
shemoves
Post by shemoves »
What are the individual gear ratios on the Legacy SS 5mt?
shemoves
Post by shemoves »
Thanks for the link, but it does not show individual gearing for most Legs
Oh, guess not.
That was misleading, so I took an FSM pic just for you.
http://thawa.net/gallery2/v/AWD_addict/ ... ewsIndex=1
shemoves
Post by shemoves »
you=the man! thanks.
dzx
Post by dzx »
what would a 98 outback 5mt be?
///M
'93 Legacy SS - part out
shemoves
Post by shemoves »
dzx wrote:what would a 98 outback 5mt be?
It probably has the pretty 'standard' gearing with 5th being .738. Being an outback though, it might have a 4.11 or even 4.44 FD to make better use of the torque. That is just a semi-edumacated guess though.
skid542
Post by skid542 »
I would think that the 98' Outback has the 4.11 gearing, my 96' does.
Lee
A DOG
Post by A DOG »
I looked on all the lists and didn't find the ratio for my legacy. I am pulling a 5MT tranny from a 96 legacy wagon brighton edition for my 90 legacy ls wagon. I looked at the rear of the 96 differential and no sticker so does anybody know what the differential ratio is for a 1996 legacy wagon brighton edition?
1990 legacy wagon LS
cold air intake
light weight underdrive pulley
Naxos muffler(RUMBLE!!)
eventually gonna be an LSTi wagon
Look on the rear diff, on the casting part. There should be some sort of sticker on there with a code. Post that code, and I should be able to tell you what the final drive is.
A DOG
Post by A DOG »
Legacy777 wrote:Look on the rear diff, on the casting part. There should be some sort of sticker on there with a code. Post that code, and I should be able to tell you what the final drive is.
Whats the casting part? Bottom, right side, left side. I'll even take a picture of the rear differential and post it.
cold air intake
The right side I believe is where the sticker is.
Cynt
Post by Cynt »
So is a STi 6SP an option for swapping into a 91 SS 4eat 3.900 w/ LSD? :?
I swear I see numbers an my brain starts giving up...
2006 Steel Grey Impreza 2.5i wagon
1991 Black Trucklinered Legacy SS
rallyboy_96
Post by rallyboy_96 »
what is the rear diff ratio on a automatic 91 turbo legacy
rallyboy_96 wrote:what is the rear diff ratio on a automatic 91 turbo legacy
3.9
rallyboy_96
thank you.
rallyboy_96
and what about a 1993 legacy L
