Request: pictures of drivers side head
If anyone has a set of heads laying around or an engine or whatever could you get a picture of the backside of the drives side head? There should be a removable plate on there, thats what I am interested in. N/A head please. Thanks
No, the plate is on the passenger side head, for N/A's, and there is the turbo oil pick/return adapter on there for the turbo's.
On the driver side, aft of the head you only have a came seal/plug, no plate.
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
You could swap the plate and use it as an NA head, its supposed to fit. good luck
