440cc fuel injectors
Got a new part? Is it the best thing you've ever seen? Is it a complete ripoff? Let us know about your parts and service.
kleinkid
Post by kleinkid » Sat Sep 30, 2006 3:07 am
I purchased four 440cc fuel injectors from Japan and they arrived three days later. They arrived packaged very well and are in great shape, with new soft goods(o-rings etc.). $112.00 including shipping to the Seattle area. Purchased from the following e-bay seller
http://motors.search.ebay.com/_W0QQfgtp ... cNQ5fQ5fSI
Post by SILINC3R » Mon Feb 23, 2009 8:24 am
hey have been looking to service my injectors. which ones are these. ihave a 90 N/A. think grey tops so not sure if these work? also these are brand new or they have been cleaned. this would help a lot since i have to work a lot and i could just plug and play and not have to wait for them to return mine.
n2x4
Post by n2x4 » Mon Feb 23, 2009 7:38 pm
SILINC3R wrote:ihave a 90 N/A. think grey tops so not sure if these work? also these are brand new or they have been cleaned.
These will not work for you, and they are remanufactured (not brand new).
SUBARUEHS Racing
Post by SILINC3R » Mon Feb 23, 2009 11:31 pm
ok thanks very much
BSOD2600
Post by BSOD2600 » Wed Apr 22, 2009 8:27 am
I too purchased 440cc's from this same ebay seller, theglobesavinggroup. Took about a week to get to Seattle. Injectors all appear to be in good condition and just as the pictures show. Order up a few remaining gaskets and install them in a few weeks :D.
'11 WRX Limited
'94 TW | R.I.P.
chochocho
Post by chochocho » Tue Aug 18, 2009 7:33 pm
what gaskets are required?
n2x4
Post by n2x4 » Tue Aug 18, 2009 8:16 pm
chochocho wrote:what gaskets are required?
http://bbs.legacycentral.org/viewtopic.php?t=38949
SUBARUEHS Racing
impreza_GC8
Post by impreza_GC8 » Fri Aug 21, 2009 4:39 pm
Out of curiosity, where your 440s yellow top or grey top?
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
n2x4
Post by n2x4 » Fri Aug 21, 2009 4:46 pm
Grey
SUBARUEHS Racing
Post by ericem » Fri Aug 21, 2009 6:56 pm
And they are direct drop in to ej22t rails? and all I need is one extra o ring?
kbeefy
Post by kbeefy » Sat Aug 22, 2009 4:49 pm
IIRC, you'll need NA fuel rails to complete the swap. (as well as some fuel management)
'92 Legacy SS, AGX, GC coilover, ALK, 20mm ARSB, FCD, MBC, iceracer, rallyx and DD
'87 Mustang GT roadracer, to many mods to list
BSOD2600
Post by BSOD2600 » Sat Aug 22, 2009 5:59 pm
440cc 'grey tops' fit just fine into the stock turbo fuel rail.
'11 WRX Limited
'94 TW | R.I.P.
Post by ericem » Sun Aug 23, 2009 12:21 am
bought them already !
Post by ericem » Thu Aug 27, 2009 10:57 pm
got them already crazy look good too cant wait till i pop them in.
pirategmunger
Post by pirategmunger » Mon Dec 07, 2009 4:35 pm
so these 440's will fit EJ22t? stock rails?
n2x4
Post by n2x4 » Tue Dec 08, 2009 3:13 pm
pirategmunger wrote:so these 440's will fit EJ22t? stock rails?
SUBARUEHS Racing
pirategmunger
yeah I saw that....
Post by pirategmunger » Thu Dec 10, 2009 5:10 pm
I have been all over this web site... already looked at that thread but no where does it give a part number for the Injector. Any fool can plainly see all the part numbers to make the JDM 440's work but I need the Injector part number itself.
kleinkid
Post by kleinkid » Thu Dec 10, 2009 5:37 pm
So, you have plainly seen all the part numbers. OK, now I'll try to help you. Try 16611AA231, probably won't show up in USDM parts catalogues.
pirategmunger
Post by pirategmunger » Fri Dec 11, 2009 7:34 pm
thank you.
speezly
Re: 440cc fuel injectors
Post by speezly » Sat Mar 19, 2011 1:58 pm
this may be a stupid queation, but would these be a decent upgrade from the ones on my stock 93 n/a? Or are these just for turbo models? just trying to find out what i can do to get a little extra hp out of my 2.2l.
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
Post by cj91legss » Sat Mar 19, 2011 6:03 pm
440s would be way too much for your N/A, you could look for some turbo legacy injectors... they might help with a little power, but not much
they're like 370cc
speezly
Post by speezly » Sun Mar 20, 2011 11:30 pm
Thanks. Btw, what cc are the stock legacy injectors currently in my n/a? I'm really just looking to give it a tiny little upgrade from the stock n/a setup, I know its not gonna gain like 20hp off injectors or anything. I'm still new to the forums, so I appreciate you guys taking the time to answer my stupid questions.
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
Post by cj91legss » Mon Mar 21, 2011 4:19 am
i think they're in the lower 200s
farfrumwork
Post by farfrumwork » Wed Mar 23, 2011 5:34 am
Putting higher flow injectors in a otherwise stock, or even somewhat modified EJ22 (i.e. your car) will not give you any power. In fact it will most likely cause your motor to run horribly (very rich).
Larger injectors can ALLOW for more power, but do they do not GIVE power unless the motor is starved for fuel. Use the $ some other way. :)
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
speezly
Post by speezly » Wed Mar 23, 2011 3:43 pm
farfrumwork wrote:Putting higher flow injectors in a otherwise stock, or even somewhat modified EJ22 (i.e. your car) will not give you any power. In fact it will most likely cause your motor to run horribly (very rich).
Thanks for the info. I do not plan to keep the engine stock for long, but do plan on keeping it n/a and want to explore my options. I had read somewhere about larger injectors paired w/ upgraded pistons/rods producing power in n/a ej22s. Is this false info?
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
