JoeP Pro-Z MBC Install
Well I got my JoeP MBC earlier this week, and installed it last night.
I fabbed up a bracket to mount it, and then mounted it to the stock wastegate solenoid bracket that I chopped up. I'm very happy with the install, it turned out really good.
I haven't had time to adjust the boost controller yet though....just install it.
Here's pics
http://www.main.experiencetherave.com:8 ... s/joepmbc/
For reference, here's pics of the stock setup
http://www.main.experiencetherave.com:8 ... P_6012.JPG
http://www.main.experiencetherave.com:8 ... P_6013.JPG
Imprezive
Post by Imprezive »
awesome! super subtle installation to!
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Thanks!
I adjusted it on friday, it's easy to adjust, and works well. I had to turn it back down a little as I was hitting fuel cut when in the higher gears and on the freeway.
magicmike
Post by magicmike »
dont know why but none of your links ever work for me.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Probably because your ISP doesn't like the 8080 port. That port is typically specified as a proxy server port.
On any of the links I post, you can always modify the link to get it to work.
Remove the ":8080" at the end of the link, and change "http://www.main." to "https://www.main."
Like this:
https://www.main.experiencetherave.com/ ... s/joepmbc/
https://www.main.experiencetherave.com/ ... P_6012.JPG
https://www.main.experiencetherave.com/ ... P_6013.JPG
It will be slower due to it being a secure connection, but the links should work.
magicmike
Post by magicmike »
ahh you so smaht. I'll have to remember that though lol
nice work on the bracket by the way.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
magicmike wrote:nice work on the bracket by the way.
Thanks :-D
bmxkelowna
Post by bmxkelowna »
i see only two places for vacuum lines on the mbc?
does it just bleed the extra to atmo instead of back into the intake like stock?
Yup, that's exactly what it does.
It be nice if it did bleed the air back into the intake, but I don't know of any MBC that does that.
Ultimately, I'd prefer an EBC, but until I get things figured out with EM, I figured it would hurt to play with a MBC.
