ok i have a stock 91' ss, and i never have had a problem wence i have got it. well i have new plugs gaped properly, and a k & n panal filter.
well every once in a while it would drop from 9 ish lbs to 5 lbs, but it would only be temporary like say 20-30 min then back to full boost.
then about 3 days ago it would only boost 5 lbs. so i thought it might be the boost solinoid taking a shit on me.
well afte reading on here i saw that it could be the knock sensor.
so i go and check it out ans i think it has a crack in it. so i am planning on replacing that.
so now i wanted to double check that it was infact pulling timing, cause of the knock sensor. so i put on a t fitting in the wastegate line to bleed pressure and get the boost up to 9 lbs again.
so now that it is back at 9 lbs, it feels like it is just not making any power.
like it feels like it did at 5 lbs, will the knock sensor fix this?
pulling timing?
pulling timing?
cars:
- 1991 legacy SS, stock
- 2003 s2000, turbo project
- 1991 crx dx RHD
- 1990 probe gt, 12 lbs, lowered
- 1991 crx dx RHD
well now i'm just pissed... i got on it today and it was driving fine running 9 lbs. and then it just bogged.
it will compleatly bog when it goes into boost. it can drive it around out of boost as i got it hom ethat way. but damn it just won't b oost now.
what is up with it?
what is up with it?
cars:
- 1991 crx dx RHD
- 1991 crx dx RHD
ok thanks for the heads up, that was what i was going with as the knock sensor is cracked...
also it does it when i rev it if i rev part throttle it is ok but if i put it to the floor it just bogs...
so i will get a knock sensor and hopefully that will fix it
cars:
- 1991 crx dx RHD
- 1991 crx dx RHD
If you have a u-pull-it in your area try to get a knock sensor from a newer car - should cost $5 or less if you pocket it.
I think there was a revision of the k-sensor & the newer cars will have the revised part.
I repinned the plug on a '99 Impreza knock sensor (from my OBS) for use on the SS & it worked like a charm.
Boost jumped from 5psi to 8.7 & the CEL turned off.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
well this hasn't fixed the car.it is completly stock minus the removal of the boost solinoid so i could rule that out as a problem. it is inpluged and out of the car if that is a problem? the car is running straight wastegate no boost controler or anything.
now i just replaced the cracked knock sensor with a new one from subaru and it did nothing.
i unhooked the battery for 20-30 min. and pushed the brakes and what not in order to try and reset the ecu but it did not work.
the symptoms:
i can rev the car to any rpm part throttle but as soon as it goes over a certain amount it will just bog very bad.
it drives fine but even at part throttle if it sees any amount of boost it will bog.
so with this said what could be causeing this strang problem. now i have had not 1 code show up. do i have a bad bulb?
is so frustraded ... haha i just need this thing to drive normal.
the symptoms:
cars:
- 1991 crx dx RHD
- 1991 crx dx RHD
FIXED!!!!!!
wow do i feel retarded... haha
i hooked up the boost solinoid and just like that my problems were gone.
thanks arctic assassian, big thumbs up to you.
thanks to everyone else also for there help.
cars:
- 1991 crx dx RHD
- 1991 crx dx RHD
