2.2L engine rear main oil seal install depth question
OrangeSuby
Post by OrangeSuby »
Can anyone tell me how deep the engine rear main oil seal should be seated? I installed one 2 days ago and if it is seated all the way in, it leaks oil very fast! I'm guessing it should be recessed 0 to 1/4 inch into the block, but I'd like to know before I install the tranny again! I guess the factory special tool installer sets the depth, but I only have standard seal installer. Any help is appreciated!!
1992 Legacy Sports sedan turbo 2.2L automatic 4EAT transmission.
OrangeSuby
scuzzy
Re: 2.2L engine rear main oil seal install depth question
Post by scuzzy »
OrangeSuby wrote:Can anyone tell me how deep the engine rear main oil seal should be seated? I installed one 2 days ago and if it is seated all the way in, it leaks oil very fast! I'm guessing it should be recessed 0 to 1/4 inch into the block, but I'd like to know before I install the tranny again! I guess the factory special tool installer sets the depth, but I only have standard seal installer. Any help is appreciated!!
OrangeSuby
there's a notch at the bottom towards the crank which allows oil to drain from the bearing down to the oil pan, if you installed it all the way into the crank then you've covered this drain hole and that would explain the leaking.
I did mine a little more than flush with the case (just a little further in)
#82 M4 TRSCCA Rallycross
OrangeSuby
Scuzzy, Thanks. I Appreciate the information.
I would hate to pull the tranny again! Thanks.
The seal needs to be more or less flush. Take a look at the pics of the oil seal at the top of the page
www.surrealmirage.com/subaru/images/swap/11
OrangeSuby
Josh, thanks.
The pictures make it clear. Thanks again. Nice SS!
Thanks for the comments on the legacy. It started life as a FWD AT L.
These two pics show how far it's come
http://www.surrealmirage.com/subaru/ima ... rfirst.jpg
http://www.surrealmirage.com/subaru/ima ... bronco.jpg
ciper
Post by ciper »
LOL!!! I should have read the forum before posting this - http://bbs.legacycentral.org/viewtopic.php?t=33890
Sorry OrangeSuby but I could have saved you a lot of trouble if I had posted this sooner.
