so...
b/c i'm a pioneer this took me awhile.
*you are not me so you'll get it done quickly!
first thing i did was get a nice little scooper..
!*then you hack off all the screws b/c as i later found out, the risers (thats what i'm going to call them) make it so the scoop is about a 1/4 inch above the actual hood.
just take a saw and cut it down so its uniform on both sides and even all around.
then you do a nice little tape job!
i started by removing the original scoop, good luck
then i taped all around the opening where the scoop was to go.
i positioned the scoop exactly where i wanted it then i took a huge strip of masking tape and put it across the width of the hood, so it was right in front of the scoop.
this piece will help you center it properly and you can write on it and such.
then i put another pi3ce of tape behind the scoop, so i could trace out where it was going to be.
so as you can see here i just traced it out.
then if you have a TMIC you can hack away the hood so you get better airflow, i haven't done this yet but i plan to as soon as i figure out where to start
i'll add more pictures later but you then get 3m "kick ass" body/moulding attachment tape and some nail polish remover, AND a hairdryer blessed with the power to create good heat.
aaand you
1. remove all the tape from your hood
2. get a soft cloth that wont scratch you paint but has enough abrasiveness to remove dirt/etc well. i used the back of a blue sponge
clean the necessary area with the nail polish remover and dawn soap (mild).
*then take the 3M tape and just put it on around the area you're applying it to.
*heat the tape with the blowdryer and press hard on it to smooth it out and make it stick to the hood better.
*The longer you spend on this the better it will turn out. (don't spend all night...
*take off the red part of the tape while heating it still, all over.
!* i put some aerodynamic looking door insulation in the front of where the rear tape will go to prevent air from slowly eating it away over time, i thought it was a good idea.!*
position your scoop and put it on!
*now heat the tape some more and press down hard on the scoop and the tape all over, so it will stick well.
*Again, the longer you spend doing this the better it will end up
*Do this to all areas you taped and then let it sit for like 30-1hr just to make sure everything is golden
PM me if you have any questions about anything!
Zach
