Due to recent events with my car I want/need to calibrate my temperature sensor and gauge. I have a feeling that one of them is not responding properly.
As I understand it, these are a simple resistivity thermal couple.
I need to know was resistance these two sensors are supposed to read at various temperatures. I've looked in the FSM's and could find the answers.
Any help would be greatly appreciated.
Thank you.
Temp sensor and gauge calibration?
Lee
The engine coolant temp sensor has the following resistances
2.0 - 3.0 kohms @ 68 deg F
0.3 - 0.4 kohms @ 175 deg F
This is for the brown two pin plug. That is the ECU temperature sensor.
I don't believe they have the same characteristics.
