Here is the list of bushings you'll need.
RST-2020R STi Hardened Bushing - Front Control Arm Rear RH
RST-2020L STi Hardened Bushing - Front Control Arm Rear LH
RST-2021 STi Hardened Bushing - Front Control Arm Front (2 x)
RST-2023 STi Hardened Bushing - Trailing Link Front (2 x)
RST-2024 STi Hardened Bushing - Trailing Link Rear (2 x)
RST-2025 STi Hardened Bushing - Lateral Link Outer (4 x)
RST-2026F STi Hardened Bushing - Lateral Link Inner Front (2 x)
RST-2026R STi Hardened Bushing - Lateral Link Inner Rear (2 x)
RST-4153 STi Hardened Rear Diff. Mount Bushing (2 x)
RST-4150 STi Hardened Rear Diff. T-bar Bushing (2 x)
RST-2022 STi Hardened Rear Crossmember Bushing (4 x)
See all those little red circles? Those are all the bushings that I'm replacing.
I've already ordered replacement hardware for every nut, bolt and washer in the rear end, I've got a drive to crack the diff drain plug, I've got a small awl and a 4.8mm rod to push the chamfered pins out of the differential, I've got fluid for the diff and should have enough PB blaster and assorted sockets to get the job done. What I'm looking for are tips, tricks, and experiences from people that have done this to help me along.
I'm also wondering what size socket I'll need to pull the hubs off. Is it a 32mm socket?
By all accounts the long bolts that connect the trailing arms to the knuckles are the biggest PITA and I should expect to be breaking those.
This is a list of all the hardware I ordered for this project. Red boxes indicate ordered parts. The numbers outlined with the red box on the far right are the quantities. Total cost for me with a 20% MNSubaru discount was ~$128 at Morries Minnetonka Subaru. It wasn't cheap but if I'm going to do this I'm going to do it right.
I took the list above in to the parts dept and they had the parts ordered in about 10 minutes. It makes their life that much easier.
Thanks,
-Greg
