The following parts were pulled from a running JDM EJ20G "hydraulic rocker head" motor. I ran this engine for about 2000 miles and I can confirm everything worked perfectly when pulled. All prices are plus shipping, but I have a FEDEX ground account and shipping is cheap.
Diamond Ignition Coils (2 bolt, coil on plug style) - $100 for a set of 4 - These coils are in mint condition and never had a single miss on the car. These may or may not have been brand new when the PO built the motor in 2005. (They look newer). There is no cracking on any on of the coils (like the late style, single bolt coils were known for) and the contacts are clean and uncorroded.
VF10 Turbo - $150 - This is the stock VF10 turbo from early EJ20G Legacy engines. This turbo ran great on the car, never had a problem. There is virtually no shaft play and the blades look great. I've had 4 used subie turbos in my garage over the last month and this one seemed to be in the best shape.
Cams - $125 for a set of 4 - The cams look great and ran great on the car.
Valve Springs & Retainers - $15 for a set of 4 - up to 16 springs are available upon request
Intake & Exhaust valves - $30 for a set of 2 intake and 2 exhaust valves - up to 8 intake & 8 exhaust valves are available upon request
Valves Covers - $75 for both - comes with used, but non-leaking valve cover gaskets - These covers were stripped, cleaned, primed with self-etching primer and painted with Duplicolor engine enamel in loss gloss black. The covers have not been installed since being painted.
HLA's (hydraulic lash adjusters) - $30 for a set of 4 w/clips - these are about $20 each new, plus shipping from Europe or Japan
coils
http://www.flickr.com/photos/65926977@N00/2393257114
http://www.flickr.com/photos/6592697...in/photostream
cams
valve covers
http://www.flickr.com/photos/65926977@N00/2393257674
JDM EJ20G turbo, coils, cams, springs, covers, & more!
