Will 15" Legacy wheels fit over WRX brakes?
wtdash
Post by wtdash »
Jamal's Sticky states 'some 15" wheels will fit over WRX brakes....Anyone know if these will off a '99 Legacy?
Post by 555BCTurbo »
Those will not fit over the fronts...
The rears, yes...because they are the same size as T Leggy
Aerotech
Post by Aerotech »
The only 15" factory rims that clear WRX brakes in the front are from the 2.5RS.
You can look for 15" rally rims, like old Prodrives... they'll fit as well, but likely pretty expensive
Jerry
wtdash
Post by wtdash »
Thanks for the info...I'll likely just upgrade to Turbo brakes.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
PhyrraM
Post by PhyrraM »
Aerotech wrote:The only 15" factory rims that clear WRX brakes in the front are from the 2.5RS.
What years? I thought all 2.5 RSs (GC, GM and GD) had 16 inchers.
92ss satinsvoice
Post by 92ss satinsvoice »
ya there 16 not 15's
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Aerotech
Post by Aerotech »
Well, no wonder they fit... :roll:
Jerry
BXSS
Post by BXSS »
Folks have put the six spoke phone dial style Leggy rims (91-92(?3) SS, 96+OB) over WRX brakes, but the calipers had to be ground down some to fit inside the rim.
Just about any 15" rally rim (Enkei, Team Dynamics-?, OZ, ...) will fit as these are usually designed to clear 4-pots - only problem is they are expensive (Enkeis are $265/rim).
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
the_watts10
caliper grinding
Post by the_watts10 »
well if you really want the rims then just check out how much bigger the calipers are than the inside diameter of the wheel and if not to much you can grind the calipers down i had the same situation with a set of 14"s unless you just dont want to mess up the paint on the caliper!!
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
legacymax
Post by legacymax »
I have also fit the 6 SPOKE early turbo legacy over wrx brakes that have been ground down. The later t-leg won't work because of ridges in the inner wheel.
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
