Need front bumper hardware from a 90-91 non-turbo Legacy
At the very least, I need three of the big headed bolts. These guys:
http://www.main.experiencetherave.com/s ... P_8333.JPG
http://www.main.experiencetherave.com/s ... P_8332.JPG
I think I may need two or possibly four of these bolts:
http://www.main.experiencetherave.com/s ... P_8330.JPG
http://www.main.experiencetherave.com/s ... P_8328.JPG
I had some work done on the front bumper area and I think the shop really screwed things up. The parts book says I need 8 of the second bolt I posted, the other two hold the back of the bumper to the fender. They're bolt 16 in this diagram
http://www.main.experiencetherave.com/s ... iagram.jpg
The book says they're supposed to mount to a fender brace. You can see it in this diagram, part 8 & 9
However the book also says that the 90 MY was the only year to get that. So my quesiton is, how is bolt # 16 supposed to be held in place? The shop has some cheesy clip bolts. I suppose they work, but I'd prefer to get it correct.
If anyone has a 90 or 91 parts car that they could take some stuff off, I'd greatly appreciate it.
94SS_Canada
Post by 94SS_Canada »
Most of the time since i cant run back and forth to subaru all the time, i go to the farm stores where i live, they carry metric and are very helpful
Hope this helps
bump
bumpage
Ok....just need three of the big headed bolts.....
Anybody?
jp233
Post by jp233 »
I should be able to get them, when I get to the j'yard. Probably won't be until the 16th or 17th at the earliest.
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
wtdash
Post by wtdash »
Josh, I 'should' have 2 of the top two.. and probably a couple of the others. I'll check @ lunch.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
wtdash
Post by wtdash »
Update:
I have 3 of the 1st and 2 of the 2nd bolts pictured. I can't answer the question about how the 2nd bolt connects as mine are just sitting in my 'extra bolts' collection.
I can send pics of them if needed.
Let me know where to send 'em and they'll be in the mail tomorrow....Monday @ the latest.
Td
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Todd,
Thanks for the update. I do only need 3 of the big headed bolts
Also, I was curious if anyone had the metal plate that went underneith. This guy:
http://www.main.experiencetherave.com/s ... P_8447.JPG
impreza_GC8
Post by impreza_GC8 »
Are there no junkyards near you? I'm in Saint Louis MO and there's usally one or two old Legacies in one of the three yards I frequent.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
There are, but older subarus, and especially first gen legacies are pretty much non-existent down here in Houston.
