How to remove this plastic nut?
skatedees
Post by skatedees »
1991 Legacy L Wagon
EJ22 5pd MT
In an attempt to remove what I think is the speedo cable, I came across this plastic piece of $@!% nut. It's a 17mm, but the damn thing is plastic and my wrench just slips.
Here are some helpful photos:
Thanks in advance.
:smt028
1991 BJ EJ22
Aerotech
Post by Aerotech »
Slip-joint pliers (water pump pliers), the biggest one you can get in there.
Jerry
Are you just trying to remove the speedo cable? It splits on the covered part up a little bit. There is a spring that holds it together.
skatedees
Post by skatedees »
Aerotech wrote:Slip-joint pliers (water pump pliers), the biggest one you can get in there.
I'll give it a shot, thanks.
93forestpearl wrote:Are you just trying to remove the speedo cable? It splits on the covered part up a little bit. There is a spring that holds it together.
I'm dropping my trans.
1991 BJ EJ22
Matt Monson
Post by Matt Monson »
If you are dropping the trans, just use the break in the cable 2 inches further up, as suggested. You don't even need a wrench to release it.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
skatedees
Post by skatedees »
Matt Monson wrote:If you are dropping the trans, just use the break in the cable 2 inches further up, as suggested. You don't even need a wrench to release it.
Oh, OK. I get it now.
So you just pull it apart after you take off that spring, or is it threaded? Either way mine isn't coming apart easily. It was covered in corrosion. I cleaned it up, but I've been tugging and twisting and it's not moving. Am I missing something, or is it just going to be a bitch to take apart?
1991 BJ EJ22
Yeah, it should just slide apart when you take that little spring clip dealie.
skatedees
Post by skatedees »
Is it suposed to come apart right at the clip, or does it slide out of the metal tube? I pulled it apart and it came out of the tube. Is that supposed to happen or do I need a new cable now?
1991 BJ EJ22
The cable has a metal end on it that slides into the other tube. The spring grabs the notch on the metal end of the cable to hold it in place. The square end the the actual cable will be sticking out.
