How to turbo a NON-turbo?? :?
I want to do something to gain horse power to my 1991 sedan L 2.2L. It is a non turbo. I need ideas and part names of WHAT WILL WORK.
If you do not know what is needed to turbo your car then you probably are not ready to take on the project.
I turbo'd my 2.2l OBS, but I had a few turbo cars before that project & knew how to get it done.
That said I was able to run a slow but quicker than stock (17's) 16.32 seconds @ 83-84MPH in the 1/4 mile with the 2974lb (with me in it) OBS when it was N/A with a fresh tune-up + a few cheap mods.
1. Intake (I'd K&N your stock box)
2. L/W Crank pulley
3. Grounds
4. 2 1/4" high flow cat + WRX exhaust (sounded like crap on WOT & did nothing to better acceleration times)
5. Redline fluids in engine, tranny, rear diff
6. spare / jack out of the car for the runs + 1/4 tank of gas = Light-weight
I was shifting @ redline like a moron, I bet the car could have run 15's if I had shifted @ 5500rpms....
It must have been fate as if the car broke into the 15's I was not going to turbo it.
It did not so I turbo'd!
My 2.2 is a MAP phase II so it is different than phase I 2.2s but you should feel an improvement with the simple & cheap mods listed above.
2. L/W Crank pulley
3. Grounds
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
Found a few pics, now I need someone to post them for me....
If you want to turbo a dual port 2.2E you will minimally need
1. a turbo
2. a turbo exhaust manifold / up-pipe
3. a downpipe
4. a GOOD high volume/pressure fuel pump
5. all lines & fitting needed to fab turbo oil feed & drains (you could probaly use the turbo oil & coolant feeds & drains with some sweat)
6. possibly a turbo waterpump - ? if the NA one will clear the e-manifold
7. some way to get extra fuel into the motor on boost - could be simple like a FMU on your stock N/A injectors or exotic like 1000cc injectors + standalone engine management
8. some form of intercooling
You could also wire in a ej22t ECU & use it with its sensors (all that differ from the n/a motor like the MAF....) & 370cc injectors to get things running....
1. a turbo
3. a downpipe
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
With flame suit on....
Unless your current car is very CLEAN, I would just sell it and buy an SS/TW. The current price point of decent turbo Legacies is probably very close to the cost of the parts to turbo it yourself.
Thanks for posting the pics for me SubaruNation!!!!!
The Pics above are of my OBS-t which is a '99 Impreza OBS with a Turbo'd 100% stock (never opened up the motor - stock heads, Stock head gaskests, super high compression) 2.2e.
It still passes OBDII emissions inspection, has NO cels, & has been running around with boost since '04.
The underhood pic of my wagon is an old shot showing the TMIC+Alky injection set-up.
I just put the FMIC set-up on the car a few weeks back.
I actually voted keep it NA & agree with PhyrraM - SS's are soo cheep you are better off just getting one.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
Thanks.
The lip is off a V4 Type R, side skirts & mini spats are the $120 E-bay Oricari 6 piece Kit (the front spats are still on my stock bumper, ? if I spelled the company name correctly, but they are pretty well known)
As for the motor lasting more than 5 minutes - it is a 2.2 & these motors seem to like boost MUCH more than N/A 2.5s.
I've been alky injected for about 3 years now (10/08 will be exactly 3 years spraying).
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
A friend of mine just used a turbo maniflold, made his own up pipe for a T3 or something along those lines, a RRFPR, some injectors, a top mount, and that's about it. He runs somewhere around 10-12psi or so, and makes about 200whp on the 22E in his impreza L. He beats on it quite regularly. It runs fairly rich, so there's probably plenty still on table, but he doesn't want to push his luck.
