Subaru stereo install kit
MacNews
Post by MacNews »
I put a new Pioneer deck in my car this week, but can't find any Subaru-compatible install kits for it. Here is a pic of the deck:
I've found some install kits online, do you guys know which one will work?
http://www.sonicelectronix.com/item_130 ... 8900.html#
http://retailer.installationexcellence. ... C2F670354A
1992 Legacy SS -stock
RJ93SS
Post by RJ93SS »
i put one in too, but did not put the plastic trim piece back on the head unit. you can actually drill or extend the holes in the metal bracket to change the position of the unit. as far as the gap i have a tray from a unknown subaru in there but it does not fill the gap. i'm thinking i should custom make a plate for that gap.
PhyrraM
Post by PhyrraM »
What you need is the 1.5 DIN pocket.
MacNews
Post by MacNews »
Thanks PhyrraM I will look for one of those, the 1.5" DIN pocket looks so much better.
RJ93SS
Post by RJ93SS »
that mask would make my face look so much better!
tahiti350
Post by tahiti350 »
I have one of the 1.5 DIN trays, came in my wife's blue wagon with the am/fm only radio. I've been hanging onto it in case I ever put an aftermarket head unit in... not for sale, just saying they are out there. Look on the L's, basic low end models.
yazmo
Post by yazmo »
hello befofe i buy this unit i would like to know something the metal plate you have on those picture come on the car? or its custom made?
i am planning to go and check for some 1.5 din pocket on junkyard they may have it but maybe not from a legacy 1990
maybe some other model may i use that or i will have problem to crew it on my legacy 1994
bcuz its relatively just as for shippement and convert to canadian dollars
just wanna know what are my option
thx in advance
PhyrraM
Post by PhyrraM »
The metal plates on the sides are factory. To the best of my knowledge they are the same on all '90-'94 Legacys, regardless of factory installed radio.
