cracked injector... ok?
farfrumwork
Post by farfrumwork »
So I acquired a complete EJ22 (NA, '92 vintage) and full wiring harness to swap into my '85 Westy (VW).
I'm going through the motor with new seals/gaskets just about everywhere (it was dissasembled/hot tanked already).
Looking over the injectors I noticed that one of them has hairline cracks around the business end of the assy (through the plastic that surrounds the metal face that has the actual nozzle holes). Maybe 4 total cracks that radiate outward from the metal plate.
Is OK? or should I just start looking for a replacment?
Thanks,
Chad
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
glennda5id
Post by glennda5id »
I only run cracked injectors. I find I get better performance and gas mileage...but seriously, its hard to say from your description. Can you post a picture?
farfrumwork
My camera sucks so no decent pictures of the cracks.
I'm just going to look for another "red top" to replace it. The cracks are bigger than I thought too - 1 of them is not really hairline.
jefferson
Post by jefferson »
It sounds like you may be talking about the pintle cap. Those are replaceable. You should be able to get a new one from Subaru or some of the fuel injector cleaning places that clean the injectors off the vehicle. Check out witchhunterperformance.com. They have diagrams and such to help you figure out what is what.
Jeff
farfrumwork
Hey, that's exactly it. The "pintle cap" is cracked.
Cool - Thanks a ton Jeff. I'll hit up witchhunter (and maybe get a cleaning done as well)
-Chad
Witchhunter will replace the cracked cap if you get a cleaning. If you have any broken injectors they might have a spare one lying around.
