stiffer spring with stock ride height?
mexicanzero
alright so i'm looking to get a new set of struts and for financial reasons the gr2's are probably what i'm going to go for now. i just realised (by measurements) that my rear end seems to be sagging and after careful inspection on a hoist i determined that it can only be the old tired springs.
so i'm going to replace the springs at the same time as struts. now i really dont want to lower the car so are there any stiffer springs out there that will maintain stock ride height? or whats the least possible drop using a slightly stiffer spring?
i could just get new oem springs but i want to make sure there isnt anything better that i can get.
thanks
-Alex
thanks
-Alex
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
race_to_live
i am in the same position. i have a 91 ss and i want some stiffer springs but i really dont want to lower the car. what year wrx springs will fit? what about the sti springs, will they fit, how much stiffer are they? i have the gr2's on my car right now but the stock springs are just worn out. i was thinking about stiffer springs but i want the springs that work the best with the gr2's.
-91ss, 250,000mi rebuilt, tmic, tdo4, agx's w/groundcontrol, f/r strut bars, rust
-83 gl wagon...350,000mi custom dents
-62 honda 55, (moped)
-74 Yamaha rd 350
-74 Yamaha rd 350
The STi springs will drop the car a tad more than the wrx springs.
The problem is, the car sits pretty low to begin with, so any lower, unless you roll the fenders, the rear tires will rub the fender wells on some decent bumps.
Your easiest fit would be to find 04 springs, either an STi or a wrx. I noticed a stiffer ride with the wrx springs, and the gr2's, and maybe a very very minimal drop in stance.
You will need front perches for an 04 in order for them to fit on your Legacy shocks, everything else just stays the same. SOA Part #20323FA000 (2 of these).
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
91 SS 4eat
95 LSi 4eat- Sold
13 STI Sedan
So the STi uses a tapered rear spring design like 91 legacies do correct? So are the rear STi springs direct replacement for the rear 91 springs? I am looking to put STi springs on my 95 impreza, can I use the 91 rear tophat assy to install STi springs?Bdub wrote:The STi springs will drop the car a tad more than the wrx springs.
-Max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
Ended up doing some reading which answered my questions. I already have 02 wrx wagon springs and struts on the car so the springs will swap in fine in the front but I will need the 91 legacy tapered tophat/perch.ericem wrote:Pretty sure in the rear it should be fine. In the front I know for sure you need a new perch.
-Max
what is a spring perch. sounds like where the spring sits im guessing?
The perch is under the tophat on the fronts, they sit on top of the spring, under the topmount. It's two separate pieces.
The rear tophats have the perch attached, so it's all one piece, at least on the 90-91 Legacy.
91 SS 4eat
95 LSi 4eat- Sold
13 STI Sedan
91 SS 4eat
95 LSi 4eat- Sold
13 STI Sedan
Are you sure? I've got perrin wrx lowering springs on my car and I only had rubbing issues on 16x7 rims. I have a hard time seeing that you'd rub on narrower wheels. I'm not saying it's not possible, but as a rule of thumb I always try and avoid the bumps on a lowered car.Bdub wrote: The problem is, the car sits pretty low to begin with, so any lower, unless you roll the fenders, the rear tires will rub the fender wells on some decent bumps.
SUBARUEHS Racing
My car sits pretty low in the rear, slightly lower than the front and its on gr2's and 04 wrx springs.
I run the stock 15's and the 00 RS 16's and there isn't much room between the inner fender and the tire. Perhaps it's just a quirk with my car.
91 SS 4eat
95 LSi 4eat- Sold
13 STI Sedan
91 SS 4eat
95 LSi 4eat- Sold
13 STI Sedan
FWIW, I run LGT rims (16x6.5) with 205/55 tires. I have completely bottomed out my suspension in hard turns (read:both inside tires off the ground) and not had any rubbing issues. That was with stock suspension. I have not had any problems with the 04' STi stuff I'm running now either.
98-99 RS rims, the 5 spokes, are also 16x7.
Lee
so i keep asking and i think i am understanding maybe. 04 wrx lowering springs will work on a fwd 90 leg. i just need different front spring perches. correct
mexicanzero
woah holy shiat! i was never notified by email that there were any replies!
thanks guys you've cleared up alot, so wrx springs and gr2's here i come.
thanks again
-Alex
thanks again
-Alex
