Another 4EAT to 5sp WRX Swap is finished
Lurch
Post by Lurch »
My son and I did a 9 day grind last month to convert his 93 t-leg from a 4EAT automatic to an 02 WRX 5sp manual transmission. Because of this site with all the previous documented experiences, how-to's, and Q&A postings we were able to put it together, start it up, and drive it down the street on the first try.
Holy crap!!!! This car was fun with the automatic but the 5sp manual makes it scream! The auto really ate up the horsepower.
During the swap, we also did a bunch of preventive maintenance. Front wheel bearings and seals, lower ball joints, new Bosch universal O2 sensor, new OEM temp sensor, new right side front axle that blow out too soon (14 month old autozone shit). We also did the rear oil seal.
I would like to offer a special thank you to these guys for their posts and/or websites: My biggest screwup was not changing the pinion flange on the WRX differential to the old T-leg flange. I did not figure this out until I was attaching the driveshaft. That cost me 4+ hours to remove the diff, switch the flange and reinstall. It was clearly document in other posts but I simple missed it.
The next screwup was not jacking up the front of the motor when removing the auto tranny. That automatic transmission is one fat bitch! I played see-saw for a few hours until I figured it out. Again clearly documented in the haynes manual but missed by me.
Things that I learned but may not have been documented or the documentation is confusing:
  • - You need two new 100mm upper transmission bolts. I used part number 800510060.
    - I used clutch pressure plate bolt part number 800508310
    - I used flywheel bolt part number 800610740
    - The driveshaft for the WRX is too short on the second half so you have to split it and use the front pinion half and then put the t-leg on the back half. I did not figure that on out until I was fitting it in place.
    - I stripped out one of the old auto transmission mount body nuts. I had ordered the WRX bolts for those locations just in case I need them… but I reused the old bolts because the WRX bolts were different. But when I stripped one mount I was able to use this bolt to self-tap the mount and securely tighten the bolt. Part number 901030002
    - The two bolts for the front cross member is part number 901000112 which is interchangeable with 20540FC110.
    - You need to attach the shifter joint spring pin before you install the transmission. I ended up having to bolt it with a locking nut and bolt instead.
    - You need to get the lower exhaust hanger. Part number 44021AA090. I modified the auto one but I do not like it. Last time I was at UpickUPay I got one off an NA 5sp and it fit perfectly.
Pain in the Butt Issues:
  • - Removing the flex plate bolts required removing the throttle body. Then the bolt heads started to strip on two of them. Lost 4 hours on that crap. 6 point small socket a must.
    - Pedals required a lot of work to fit. This has been documented in other posts.
    - Playing see-saw getting the auto transmission out.
I end up ordering all the clutch hose parts from Jegs for $46.
  • - HOSE 14" -3AN STRT X STRT (11555-635003) $9.99
    - 10 MM BANJO BOLT (361-977517) $4.69
    - BANJO 3 TO 10MM (11361-997631) $8.99
    - #3 TO 10MM BRAKE ADAPTER (11799-641431) 11.99
    Plus $10 shipping
Here are some pictures from the conversion. Click on them to get a larger image.
WRX 5sp drive train components.
WRX Flywheel with mild hot spots before machining.
WRX flywheel after machine.
I removed the IC to get to the transmission.
Auto transmission out of the car.
Auto tranny vs 5sp tranny.
The transmission is out.
Flexplate that the torque converter connects to.
Drive train (Differential, axles, and driveshaft) out.
Auto shifter removed.
Under the dash pointing to the TCU. Just left of the steering column.
5sp pedal installed. Not as easy as it looked.
The T-Leg's 3:90 diff on the left and the WRX 3:55 on the right.
More missing drive train and me under the car toward the front.
New Exedy clutch installed.
Hydraulic clutch components.
Hydraulic clutch complete.
I blogged the same information here.
James
93 Legacy Turbo SS Burgundy - Son's Car
Mods: KYB GR2, K&N, TD04/WRX TMIC, Hallman Pro MBC @ 11.5 psi, 02 WRX 5sp Tranny, AU CB 97-00 WRX 3" Turbo back Exhaust / Future Mods: MSD DIS2
02 Toyota Tundra v8 4x4 TRD & 97 Suzuki Bandit 1200s- Mine
skatedees
Post by skatedees »
Congrats!!
Greatest follow up ever........
1991 BJ EJ22
Excellent comments on the swap!!
Yeah removing the 4EAT is a HUGE pain in the butt!
dropdfocus
Post by dropdfocus »
Edit: **Nevermind, found the answer I was looking for...**
Jason
Post by SubaruNation »
subscribing!
Spilner
Post by Spilner »
Did you use the wrx pedals?
Lurch
Post by Lurch »
I'm not sure if it was from an RS or WRX. I got them for free when I bought an O2 WRX turbo and IC. From all the pictures and mechanical drawings I have seen, they all look the same for 91-94 t-legs and imprezas up through 02/03 WRX. Beyond that year I can not say for sure.
James
dropdfocus
The 5MT pedal box is the same on the cars. They only changed when they switch over to TBW (throttle by wire). The only thing that makes the WRX or STi special is the pedal covers.
Jason
trev0006
Re: Another 4EAT to 5sp WRX Swap is finished
Post by trev0006 »
thanks for the links.
Lurch wrote:My son and I did a 9 day grind last month to convert his 93 t-leg from a 4EAT automatic to an 02 WRX 5sp manual transmission. Because of this site with all the previous documented experiences, how-to's, and Q&A postings we were able to put it together, start it up, and drive it down the street on the first try.
    Plus $10 shipping
