i searched but couldn't find a solution here. if anyone knows of a local place besides autozone or advance auto (no luck) or even an oem part number would be useful.
thanks!
I'm assuming i need the cable in the middle? 91 AT but whats the difference between the middle picture and the one under it.
SiCkSTi04 wrote:I'm assuming i need the cable in the middle? 91 AT but whats the difference between the middle picture and the one under it.
I'd highly suggest you replace the whole cable, not just the shaft. Over the years, gunk will build up in the cable and its lubrication will get old/etc.
As for the cable differences, look at that 2nd picture. The last cable is for 90 AT's while the others go for the other years. Probably one is longer be a little bit...
