looking to replace the stock clutch/flywheel setup.
looking for something that'll handle 300hp/300tq.
thanks in advance.
yat
recommendation for clutch/flywheel combo for a 91 legacy
try this. its only a stock replacement clutch but would probably be ok at 300 hp if you're nice to it.
http://cgi.ebay.com/ebaymotors/EXEDY-CL ... 2506wt_907
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Re: recommendation for clutch/flywheel combo for a 91 legacy
I went with the exedy lightweight flywheel and a stage one clutch that was meant for a WRX. Everything went together like legos. I did remove the metal cover on the underside of the engine that covers the bottom of the flywheel, as the clearance was bit close. I love the combo as well.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
thanks for the reply. i haven't installed it yet but i went with the ACT street clutch kit with a streetlite flywheel.
im lookin for the same thing. in your car turbo?
It would have to be a turbo car - Only the turbo transmissions would accept a WRX clutch.
SUBARUEHS Racing
yes, my car is a 91 legacy turbo. it is installed but i have yet to pick up the car.jeffrhomola33 wrote:im lookin for the same thing. in your car turbo?
I have the ACT street disk as well, with a factory pressure plate and flywheel. No issues, it grabs hard and puts up with my abuse.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
