5MT internals the same?
Binford
Post by Binford »
Are the turbo 5MTs the same gear ratios as the non-turbos? I'm talking about 1st, 2nd, 3rd, etc. I know the differentials are different. Anybody here know?
91legacysport
Re: 5MT internals the same?
Post by 91legacysport »
I would also like to know the same thing.
BSOD2600
Post by BSOD2600 »
'11 WRX Limited
'94 TW | R.I.P.
91legacysport
My question is still a little unanswered. Can you inner change parts between the turbo trans and the non turbo trans.
92 Rally
Post by 92 Rally »
No, Things change from year to year and model to model. I made a Frankenstein transmission for our SS Legacy out of 4 different transmissions. Let me tell you, this was a BITCH! Differences between gears and the actual case very throughout the years. I found it to all be trial and error.
[b][color=white]-Ryan-[/color][/b]
"We live for a good time, not for a long time." -Colin Mcrae
[url=http://wrxmodders.com/forums/viewtopic.php?t=15103]Project RallyX: 1991 Turbo Legacy[/url]
91legacysport
92 Rally wrote:No, Things change from year to year and model to model. I made a Frankenstein transmission for our SS Legacy out of 4 different transmissions. Let me tell you, this was a BITCH! Differences between gears and the actual case very throughout the years. I found it to all be trial and error.
When I use car-part.com i only come up with one option fro a 91 ss but when i search for 92-94 i get tons of transmissions. The price is also much more expensive for the 92-94 vs the 91. is ther a actual differenct in the 91 vs the 92-94.
92 Rally
Post by 92 Rally »
That I can not tell you. I would ASSUME so, but not 100% on it. I can tell you for a fact that the WRX's very from year to year. And the transmission case from the 90's is different then the current 5mt.
There gear ratios may be the same, but as discussed there are small changes to how the internals are put together, syncros, etc. The best I can suggest is to download the parts book from me and compare the part #'s for certain components in the transmission and see what part #'s are the same or different.
Here's the thread with the link to d/l
http://bbs.legacycentral.org/viewtopic.php?t=30531
91legacysport
Legacy777 wrote:There gear ratios may be the same, but as discussed there are small changes to how the internals are put together, syncros, etc. The best I can suggest is to download the parts book from me and compare the part #'s for certain components in the transmission and see what part #'s are the same or different.
Awesome information. Thank you sir. My questions have all been answered.
Binford
Post by Binford »
Yes, thank you! I'm looking to mix and match some parts out of my several "broken" transmissions and come up with one or two "usable" ones. :D
