I have some 04 WRX springs sitting around and am in search of WRX struts to put them on for my friends 92 Legacy LS. I read in the sticky above that this setup can cause the spring to be loose? Is this true? Other then STI struts is there another option for struts (OEM) not KYB's or anything. I am looking at more so 02-07 WRX Struts.
WRX Struts on 92 Legacy
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
Re: WRX Struts on 92 Legacy
It's been a while since I've read that sticky, but I'm guessing the springs are a slightly smaller than the strut perch. Would that be correct? You could try using some rubber cushions to help take up the extra room. If I'm way off base let me know.
yes, with this set up the springs are slightly short for the struts. I used some 05 wrx struts with some 05 sti springs and everything works fine. The spring shortness is so minimal, I didn't notice a difference but the handling difference is amazing compared to our oem "wore-out" suspension.
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
I just installed 06 WRX suspension (springs/struts) Rear top hats/strut mounts were from a 90 Legacy. Since she owns a 92 LS. Everything bolted right up. The rears were kind of a pain to get in at first. But the improvement is amazing just like it was on my 96 L.
