Intake Help!
Subi-swap94
Intake Help!
Post by Subi-swap94 »
So guys, I have a issue and I'm hoping one of you guys can lead me in the right direction.
so you know the black intake hose that goes from the Air cleaner to the turbocharger?
well mine is old and its starting to crack. So im on the look out for another one but if possible better shape.
but i blew the hose off the other day and i went to put it back into place when i got home and i went to start the car. It will run for a good 10-15 seconds then it will die, and now my check engine light is on. I'm at a loss, anything will help
Current Cars
'94 Legacy SS - EJ20G VF22, 5MT
'70 Ford Maverick - 302 small block, C6 AT
BSOD2600
Re: Intake Help!
Post by BSOD2600 »
pull the codes http://legacycentral.org/library/literature/codes.htm
make sure you didnt accidentally disconnect the hoses when fiddling with the intake tubing.
'11 WRX Limited
'94 TW | R.I.P.
Subi-swap94
Re: Intake Help!
I made sure all the tubing was in place, still same result
Current Cars
jefferson
Re: Intake Help!
Post by jefferson »
It is very possible you aren't getting a good seal and it is pulling air after the maf. They don't like that. Not too clear on exactly which hose you are talking about as there are actually two. Both are 90 degree elbows on either side of the resonator box. The 90 at the turbo is subject to alot of heat and gets real hard and then it doesn't want to seal well. If it is that one I would just get a new one.
Jeff
Subi-swap94
Re: Intake Help!
Now that it's put all back together, it will run really rough
And it won't stay running longer than 15 seconds. Now my check engine light is on.
I'm at a complete loss.
Current Cars
Re: Intake Help!
check the codes, and get back to us.
Subi-swap94
Re: Intake Help!
I don't have a code reader and my car won't run long enough to get to one.
Current Cars
jefferson
Re: Intake Help!
Post by jefferson »
There is a link in the first post on how to check the codes.
91'firebreather
Re: Intake Help!
Post by 91'firebreather »
I had that problem with my ss I have been through 3 in three years only place I can find it is a the dealer
As it is a special order part for $80.00
The car ran like crap before I got a new one
