05 legacy Gt swap, what speedo gear to use on TW
njdriver04
Post by njdriver04 »
Hey guys my buddy has a 05 gt trany, the price is right so I am going with it, only issue is the electronic speed sender unit needs to be converted to a mechanical setup by cracking the case and inserting the gear, What would be the best speedo gear to use to match the my 94 TW? any charts for this, thanxs in advance.
'04 forester XT
Scoob Alumni
'94 TW, '96 L, '00 GT
sqc151
Re: 05 legacy Gt swap, what speedo gear to use on TW
Post by sqc151 »
you can probly get the right piece from the dealer. or use GPS... :mrgreen:
i was gonna say, i might have another transmission this fall. but not sure how long you wanna wait. i have the peddles and the hydraulic stuff out of the red car if you need to swap into your 94 TW.
You can't go without it. That's where the ECU gets it's speed reading from and without it your car will be in limp mode. It will hit fuel cut at very low boost and the check engine light will probably come on.
njdriver04
little reading on other threads on rs25 and nasioc, i realized i need the speedo gear for a 4.11 tranny, now i am wondering what sensor itself to use.
'04 forester XT
Scoob Alumni
Are the speedo gears in the tranny's actually different depending on what FD ratio the trans is? I've always wondered that. People swap transmissions and rear diffs all the time with different FD ratios and nobody ever mentions their speedo being off but my 4.444 forester trans is way off. At 100 mph on my speedo I'm really only doing 90mph. It's pretty annoying.
njdriver04
http://forums.nasioc.com/forums/showthr ... ?t=1532432
this thread has part numbers for the 4.11 and 4.44
'04 forester XT
Scoob Alumni
njdriver04
are the sensors on the manual and auto the same part?
'04 forester XT
Scoob Alumni
crisco
Post by crisco »
hey its an older threaad but i was wondering how things went?
i am installing a 03 impreza TS trans into my 93 legacy turbo... 5MT / same final drive etc.
so i am assuming i will need to open the trans case and install a mechanical speed sensor sending unit - is this what you did? any tips? should just get it out of the old one or get a new one to go in?
Thanks a bunch!
--- crisco --- 2005 Saab 9-2X Aero---
crisco
Post by crisco »
got my trans... just need the clutch stuff and its going in
njdriver04
I ended up getting a 04 forester xt 4.44 trans, that I don't have to crack open, I will look around to see where I read up doing the mechanical speedo gear install.
'04 forester XT
Scoob Alumni
