Cams
Re: Cams
From what I understand the cam on the passenger side comes out the rear and there isn't enought room for it to do so. So I guess I am saying yes. Maybe someone knows a trick that will chime in.
Jeff
Jeff
Re: Cams
The passenger side cam is shorter, and might come out. I haven't tried it, maybe someone that has or hasn't done it can comment.
Re: Cams
No need to remove the engine, the passenger side cam slides right out no problems. The drivers side comes out with a little finess, it bumps into the ac condenser, but it's manageable to get it out without removing the condenser.
This was done on a na ej22
93 legacy l
to much to list....
to much to list....
Re: Cams
Its possible, but its so much easier to do it with the engine out. And its relatively easy to pull a motor out of a subie.
