any chance the forum could be changed so that link open in a new window? (90% of browsers open into new tab)
there's been a few times where ive clicked a link to read something and forget to go back and closed the window(tab)
Links
Re: Links
i do the same most of the time, but there always the times you forget haha
Re: Links
use the scroll wheel button, does it in a new tab
93 Winestone TW project
Re: Links
Unfortunately there's not an easy setting to change this behavior. I'm sure there is a hack out there that would do this, but Dave's preference is not to run hacks because they need to be applied every time the software needs to be updated, which can be a pain since sometimes the hacks are not updated when the phpBB software is updated.
I too use the scroll wheel button to open the links in a new window.
Re: Links
being on a mac lap top i dont have a scroll wheel to click haha
no worries if it isnt an easy fix! ill have to keep my finger on the command button more
Re: Links
There may be a behavior for it depending on what browser you're using. And, depending on the age of the laptop, there may be a gesture for center click on the touch pad. Try two fingered tap on the touch pad.
