Ya know those little white clips that hold the door jamb weatherstrip to the doors? Well, while I was replacing one of my doors weatherstrip (it was torn from being frozen to the jamb last winter), I broke nearly every single clip.
So I found that most of the Subaru parts sites charge about $1.50-$2.00 PER CLIP. That's before shipping. So I would be paying $40 easy to replace them all.
That's until I found these:
http://www.clipsandfasteners.com/Subaru ... a21565.htm
About $11 after shipping and 25 clips per box. Just installed them and they fit just like the originals! Satisfied to say the least.
Source for door weatherstrip clips.
Re: Source for door weatherstrip clips.
Ha, awesome find! Thanks! I'm making a note of this
I have the exact opposite problem.... my clips are all fine but the weatherstripping on all 4 of my doors (esp. the rear doors) is just flopping around and won't stay clipped as the rubber is ripped where it should fasten in just about every case.
I need to find a good source for the replacement strips. Where did you get yours and what did they cost ya?
-Chris
91SS 4EAT stock
91SS 5MT awaiting engine rebuild and VF36...
92SS 4EAT - RIP
94SS 5MT4.11+rLSD 289k km: RobTune550,TD05-16g @ 18psi,FMIC,3"TBE,Forester lift
91SS 4EAT stock
92SS 4EAT - RIP
I was lucky and found a very low mileage 1991 Legacy wagon (same color as mine, even) in the local junkyard. I pulled nearly all of the weatherstrip off the car for like $25 and put it on my car. Nearly perfect condition.
Pull-and-save in Spokane, WA has like 13 BC/BF Legacies on the yard at any given time.
But I bet you'll spend $4-500 on weatherstrip for all four doors if you bought new.
All new weather stripping would be superb. Under the hood too. Mine under the hood is torn where those clips go and comes loose all the time.
Yeah, it's about time to find the junkyards around here that have Subarus. That's a bit too much new lol
I hadn't taken a look at the hood clips, I wonder if they're the same as the door clips?
-Chris
91SS 4EAT stock
92SS 4EAT - RIP
91SS 4EAT stock
92SS 4EAT - RIP
the weather strip clips are the same on all subarus
new weather stripping is not cheap I think I priced out the front doors and its $160 ea with clips
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
