dome light help
ugaucin
dome light help
Post by ugaucin »
My dome isn't working on the auto position. Doors are open and it doesn't turn on. When i switch it to the on position it works. Help please.
Uriel
1994 N/A Sedan-Daily driver
1994 Touring Wagon 4EAT-Project car #1
Re: dome light help
In the auto position the dome light goes through the gauge cluster where it shows the doors are open. If the gauge cluster is out or something isn't working associated with that, the dome light in the auto position may not work.
ugaucin
Re: dome light help
Post by ugaucin »
Legacy777 wrote:In the auto position the dome light goes through the gauge cluster where it shows the doors are open. If the gauge cluster is out or something isn't working associated with that, the dome light in the auto position may not work.
It still shows the door open on the cluster. like it should
Uriel
oldscoobyturbo
Re: dome light help
Post by oldscoobyturbo »
door switches need to have clean grounds on the mounting screws at the door jam to work properly
often times you will find the rubber stopper missing on the door or the switch rubber covers get damages and jam the switch
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
ugaucin
Re: dome light help
Post by ugaucin »
I know its been long since this post. But I still need help. My dome light still doesn't light up with my doors and its irritating me.
Uriel
Re: dome light help
When I did my 6spd swap I had the gauge cluster out. With the gauge cluster out the dome light did not work with the doors. If your dome light works in the ON position, but not the doors, I would suspect the issue is related to the gauge cluster setup.
Have you done anything with the gauge cluster or are using a different gauge cluster? Do you have an auto or manual trans?
Re: dome light help
diesel devil wrote:door switches need to have clean grounds on the mounting screws at the door jam to work properly
Our cars (or at least mine) don't have a screw that mounts the trigger to indicate if the door is open or closed. It's just a plastic body with said button that just pops into the hole where it's mounted, i.e. it's a 2 wire button. Depressed it completes the circuit and pressed the circuit is open and not making contact.
ugaucin
Re: dome light help
Post by ugaucin »
Legacy777 wrote:When I did my 6spd swap I had the gauge cluster out. With the gauge cluster out the dome light did not work with the doors. If your dome light works in the ON position, but not the doors, I would suspect the issue is related to the gauge cluster setup.
I have a 94 but I had to put a 92 cluster on it cause my 94 cluster broke. But I decide to cut the wires going to the dome light.(don't ask why. Stupid thinking on my part) so after I soldered the wires back together it no long worked. So I don't know. That's what started all this.
Uriel
Re: dome light help
Are you sure you got the wires soldered back together properly?
Do you still have the 92 cluster?
Do the door indicator lights in the cluster work? If you open the driver's door, does it show that in the gauge cluster?
ugaucin
Re: dome light help
Post by ugaucin »
Legacy777 wrote:Are you sure you got the wires soldered back together properly?
Yeah still on there. Works fine. All doors indicators work, on all 4 doors it shows open when open
Uriel
Re: dome light help
Hmm....well since it happened after those two events, gauge cluster change out and the wiring getting cut, it's likely one of those two things. If you're absolutely 100% positive the wiring was reconnected properly, then it's likely something to do with the gauge cluster.
I know there were some wiring differences between the years, but don't know for sure if there's any difference between the 92 & 94. I think to troubleshoot it further, you'd have to pull the gauge cluster and do some checking on the wiring from the gauge cluster to the dome light to make sure that's good. If so, then we'd need to figure out the differences in the 94 cluster so you can repin your harness to match the 94.
ugaucin
Re: dome light help
Post by ugaucin »
Legacy777 wrote:Hmm....well since it happened after those two events, gauge cluster change out and the wiring getting cut, it's likely one of those two things. If you're absolutely 100% positive the wiring was reconnected properly, then it's likely something to do with the gauge cluster.
Well the 92 cluster worked fine with the dome light, up to until cut them.
Uriel
Re: dome light help
Ok, then it's something with the wiring or how they were connected back together.
ugaucin
Re: dome light help
Post by ugaucin »
Legacy777 wrote:Ok, then it's something with the wiring or how they were connected back together.
Well I solder them back together excalty the same. I'm going to redo them tomorrow. I'll take a video if it still doesn't work so you can see.
Uriel
ugaucin
Re: dome light help
Post by ugaucin »
http://www.youtube.com/watch?v=5eZl9YO0 ... e=youtu.be
Uriel
Re: dome light help
Hmmm
Do you have a multi meter or test light? I would suggest checking the wiring with the multimeter. The black wire with white stripe should have 12v going to it. The black wire should be providing a ground when a door is open. You can check this by checking the resistance from the wire to a known good ground.
When you do the checks, check before and after the connection point.
ugaucin
Re: dome light help
Post by ugaucin »
Legacy777 wrote:Hmmm
Well tested it today. I think it might be the switch that's bad. When I tested. On the "on" position it gave my 11.6 volts. On the "auto" position, it gave me 0.003 volts, and on the "off" position it gave 11.6 volts again. I don't know what to do now
Uriel
Re: dome light help
It seems like the auto & off positions are backwards.
ugaucin
Re: dome light help
Post by ugaucin »
Got a new dome light today. It gives me the same problem.
Uriel
Re: dome light help
Hmmm....I'm not sure what to tell you then.
