suspension woes
Someperson
suspension woes
Post by Someperson »
having trouble understanding the compilation thread, I'm looking at a set of 06 sti coils for my 92 SS. i'm 99% sure that they'll fit with new tophats but i wanted to throw it out for confirmation first. Thanks
93 Winestone TW project
Someperson
Re: suspension woes
also wondering about an 06 bellmouth DP, also 99% sure it'll fit
matt00rs25
Re: suspension woes
Post by matt00rs25 »
Down pipe should fit. I know anything impreza rs is a direct fit suspension wise.
Someperson
Re: suspension woes
ppl put in sti struts so i'm pretty sure the coils will fit...
oldscoobyturbo
Re: suspension woes
Post by oldscoobyturbo »
with the correct top mounts the springs will fit
downpipe will fit too just take note that the top O2 sensor might not have a bung
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Someperson
Re: suspension woes
coils as in coilovers, should've clarified
wtdash
Re: suspension woes
Post by wtdash »
I'm not familiar w/coilovers, but 2004 STi struts were the only year the fronts were a direct fit. The '05+ front bottom bolt holes were changed and won't fit 'as is'. Some have drilled them out to work - that's up to you.
The front tops whould work, but as stated you'll need your rear top hats.....but not sure if coilovers require something 'special'.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Someperson
Re: suspension woes
Ahh, fun. Could always order new tops for gc-gf fitment
