1992 legacy tw from Montana
I had a post on here but it was long ago, idk were it is so here is a new one.
Specs:
1992 touring wagon
5mt swap (01 foz trans 4.11)
Tdo4
Wrx tmic
3in turbo back
Ej22e block
Ej25d heads (clover heads)
Megan racing coils
Some random uni lug 17's
Stock ej22t ecu
FCD
Wrx 11.4" front brakes
Runs 15psi all day and loves it
Specs:
1992 touring wagon
Tdo4
Wrx tmic
3in turbo back
Ej22e block
Megan racing coils
Stock ej22t ecu
FCD
Re: 1992 legacy tw from Montana
i'm jealous
Nice Car!!
Very Nice
Welcome back and clean looking TW.
HI,
Been thinking of doing this also:
You running the stock pink injectors? What fuel rails - EJ20G?
TD
This should keep your CR @ about 8:1+. Stock NA pistons seem to hold up per others' experience.Ej22e block
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Its calculated at 8.6:1 on the dot.
Stock injectors, I actually built a set of 22 rails with 25 tabs welded to them, rails have mounts for 22 or 25 intake. Never caused an issue.
I'd reccomend everyone does the 22e/dohc combo, yields perfect cr yet 22e bottom ends and 25d heads are fairly common. Also performs better then single cam and also allows you to save the legendary closed deck bottom end our cars came with.
Only slight mods need to be done for turbo coolant and oil.. I'd build aother one in a heart beat.
im also boosting a n/a 2.2 block, i used sohc 2.5 heads though since i had a few sets. i drive it HARD and in 3 years its never given me a issue. get a robtune ecu, that will wake it up even more!
*sold*
*sold*
One of these two is getting a 6mt here soon sedan is something I'm wrx ecu merging.. There is a thread in electrical fer sedan swap.
What HG?legsportwag wrote:I had a post on here but it was long ago, idk were it is so here is a new one.
Specs:
1992 touring wagon
Tdo4
Wrx tmic
3in turbo back
Ej22e block
Megan racing coils
Stock ej22t ecu
FCD
How did U run the oil and specifically the coolant?
I know the DOHC heads have an oil supply and not too tough to run the oil drain back into the valve cover, but a good coolant source/return isn't as clear.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
theres a thread somewhere that gives step by step instructions on tapping the dohc heads for coolant. its really easy
*sold*
*sold*
Yeah - I followed THIS THREAD(pg. 3)...I had it done on my '90 T-wagon...by a local Subie shop....and it leaked. So, wanted to hear about other options.MikeyMeyagi wrote:theres a thread somewhere that gives step by step instructions on tapping the dohc heads for coolant. its really easy
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
I just came across an old post of yours (last year) ....didn't you used to have an EJ257 under those heads? And did you ever figure out your idle issue running that combo?
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Yep had a 257 under a different set of 25d heads. Not the best compression ratio though (9.3:1). Was spunky but that motor let go before I figured out the idle issue. Ended up being an issue in the engine harness but long since cured.
New engine combo (97 22e block, 97 25d heads) yeilds a much safer compression ratio (8.5:1) also the stock ecu compensates much better with stock engine cc's
