idle vacuum psi
turbo970
idle vacuum psi
Post by turbo970 »
i been reading some threads and was wondering if -12 psi was a normal idle reading on a boost gauge. i read a few threads where others were having -18 psi at idle
alexandermf
Re: idle vacuum psi
Post by alexandermf »
Me and Chris both run around 16-19 mine usually hovers over 18 with a warmed up idle. But i think our altitude has something to do with it vs vac readings at sea level
turbo970
Re: idle vacuum psi
Post by turbo970 »
i'm at 7000 ft above sea level but running a stock turbo
James614
Re: idle vacuum psi
Post by James614 »
I pull 17-18 near idle. Id guess you have a vacuum leak.
matt00rs25
Re: idle vacuum psi
Post by matt00rs25 »
19-20 and I'm right at sea level
Re: idle vacuum psi
Idle vacuum is going to vary on elevation. Check out this post for the ambient pressure at different altitudes.
http://bbs.legacycentral.org/viewtopic. ... on#p381936
I think 12 in-hg is probably a little lower than it should be.
turbo970
Re: idle vacuum psi
Post by turbo970 »
i went threw all the vacuum lines today replaced 2 and zip tied them all. now at idle it reads -14 i cant figure out why it wont hit -18.
lucas
Re: idle vacuum psi
Post by lucas »
because pressure altitude lowers it.
1993 legacy ss "Shela"
Re: idle vacuum psi
Your vacuum reading of around 14 in-hg is about where it should be for 7,000 ft.
turbo970
Re: idle vacuum psi
Post by turbo970 »
it kind of bounces but it runs fine. i did notice my brake pedal got firmer after replacing the 2 vacuum lines. and the boost comes in a lil sooner. just wish i had the funds to do the td04 up grade
