I have a wrx metal coolant tank installed and I want to double check that I have the hoses hooked up correctly.
As for the turbo coolant hoses.
The top hose is coolant return?
And bottom u shaped hose is the coolant feed??.....
The red line is going from the bottom of the tank to the coolant crossover. The yellow is going from the top of the tank to the top coolant line on the turbo. The green goes to the radiator. And the blue goes to the over flow tank.
Is this the correct way to hook it up?
Sent from my SCH-I545 using Tapatalk
Coolant lines for turbo and coolant tank
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
Re: Coolant lines for turbo and coolant tank
You got it right, that's exactly how mine was ran before my swap.
