4.44 and rear diff swap
bcmaxx
Post by bcmaxx »
My wrx 2.0 , upgraded 4eat and 4.44 swap almost complete, couple things I'm up against on the rear diff swap:
outer cv axle stubs are seized in the hubs. and by seized I mean, I'll mushroom them trying to get them out... I need the different style rear cv with the stubs for the newer diff. Can I just swap the inner stub housing cups, new new boots and grease and keep my original shafts and outer joints? or retain my stock outers , just swap on the newer style shafts withthe stub inner joints?
and how should the pinion flange be swapped? are they torued or crush collar type? I come from a land of truck rear diffs, these are new to me!
bcmaxx
Re: 4.44 and rear diff swap
Post by bcmaxx »
bump! may go ahead and find out
rallyak
Post by rallyak »
The pinion yoke can be swapped off your old diff and toqued to 150 lbs (I believe) and that's good. The axels you need are from 95-99 legacy outback to match up with our hubs and plugs in to the newer diff.
Charles
bcmaxx
Post by bcmaxx »
Diff swap and 05 impreza rear suspension and knuckles all bolted in perfectly. 05 impreza axles also fit great!
bcmaxx
Post by bcmaxx »
just to update! 98 outback 4eat works perfectly in every aspect,and with the original tcu
