Exterior trim weather stripping
SubyFusion
Post by SubyFusion »
I am in the process of repainting the trim on the legacy, and the rubber around the rear window trim is shot, does anyone know if it is still available? or has someone here used something to replace it?
Thanks, Brian
1992 Legacy L (AWD )(5MT)[2.5RS Trans] EJ22T Swap in Progress
Re: Exterior trim weather stripping
I don't think you can buy it separately from Subaru. There is bound to be something that would work in its place. I'd like to know because I will need some when I ever get around to putting the side skirts on my car. My best suggestion would be to talk with a few body shops or body shop supply stores for a "generic" solution that works.
