20g valve pucks.
The.wee.baby.seamus
20g valve pucks.
Post by The.wee.baby.seamus »
So I have these version 2 sti heads and I'm trying to figure out how these valve adjuster shim over buckets work. They look to be hydraulic but there isn't any adjustment screw or anything like that. How do they work? How do I adjust them?
Alphius
Re: 20g valve pucks.
Post by Alphius »
There is no adjustment on hydraulic lifters. "Hydraulic Lash Adjuster" or HLA means it takes care of that all on it's own.
Shim over bucket is a completely different thing, which you do not have.
The.wee.baby.seamus
Alphius wrote:There is no adjustment on hydraulic lifters. "Hydraulic Lash Adjuster" or HLA means it takes care of that all on it's own.
You sir are a master. Thank you for all your wealth of knowledge. You sir are the man. This is great news for me. Makes this whole process so much easier. Standard 2.0 valves will work in the heads correct? Standard turbo valves. I.e. 205, 255 valves. GSC makes a good valve.
Alphius
Post by Alphius »
I've never heard of using EJ205/255/257 valves in EJ20G heads. I have no idea if they would work. Maybe someone else has tried it?
The.wee.baby.seamus
I'll check the valves tomorrow. See what the measure up to. And get back to you.
Moved to engine section
Made the pictures links due to the large size.
