hi to all members.i put in my vw beetle an ej22 91 model .the donor car had manual trans.
my question is. should I ground this single wire from b58 pin 10.? or leave it free.? thanks.
should I fabricated a switch just to imitate the original neutral switch.?
neutral switch b58 10 pin connection
Re: neutral switch b58 10 pin connection
Hi George,
What did you end up doing with this?
