Wanted 1992-94 Sunroof switch & Blue Control Box
Olduser1
Post by Olduser1 »
Yes I'm still on the look out for 2 parts for my 1992 Legacy turbo over in England.
First the roof mounted switch for sunroof above the rear view mirror , light grey or even just the switch up down itself as I have 'repaired' mine twice to no avail
Also the blue control box for the sunroof again if you have spare relays that work I'll take just those parts. As the originals no longer available unless you purchase a box of 200.
The control unit is behind the roof covering & mounted in rear of the roof along side the s r motor.
Please note I'm in England so need to find a solution if these parts turn up this Spring.
