Ok going for the timing belt and water pump
replacement this Saturday.
Since I’ll be down there what else should be changed
or fixed?
How many hours do you think this might take if I have
tools available?
Do I use a Subaru belt? Or do you suggest a different
brand?
Model #?
Thanks!
John
91 Sport sedan (133000 miles)
__________________________________________________
Do You Yahoo!?
Great stuff seeking new owners in Yahoo! Auctions!
http://auctions.yahoo.com
Monitoring Service trial
http://us.click.yahoo.com/ACHqaB/bQ8CAA ... /XoTolB/TM
What else to replace with Tbelt?
Rod Grosvenor
Also, replace ALL seals (oil pump, cam & crank)-look CAREFULLY at the oil
pump-they tend to leak externally after 100k-possibly replace as a good
maintenance procedure. Have a dealer/Subie tech check the tensioner & idler
while you have it apart. If you`re going to all the trouble of getting into
the front of the engine, make sure you don`t skip these items. It`s more
time & money, but less hassle later & cheaper than a re-do (take it from
someone who knows.)---ROD (AZ.)
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Sunday, February 03, 2002 8:26 PM
Subject: [BC-BFLegacyWorks] What else to replace with Tbelt?
> Since I'll be down there what else should be changed
> or fixed?
> tools available?
> brand?
> Model #?
> Thanks!
> John
> Do You Yahoo!?
> or fixed?
> tools available?
> brand?
> Model #?
> Thanks!
> John
> Do You Yahoo!?
Doug Hancock
yep replace the seals as you will have trouble before its time to replace
the belt
-----Original Message-----
Sent: Monday, 4 February 2002 3:18 PM
Subject: Re: [BC-BFLegacyWorks] What else to replace with Tbelt?
> or fixed?
> tools available?
> brand?
> Model #?
> Thanks!
> John
> Do You Yahoo!?
Access Your PC from Anywhere
Check Email & Transfer files - Free Download
http://us.click.yahoo.com/omECdA/3XkDAA ... /XoTolB/TM
the belt
> or fixed?
> tools available?
> brand?
> Model #?
> Thanks!
> John
> Do You Yahoo!?
