Legacy Turbo ECU Pinout Diagram Needed
Posted: Tue Feb 10, 2004 9:31 pm
by MY99 2.5GT
I am in need of a Pinout Diagram for a Legacy Turbo ECU.
I'm not sure if the ECU or wiring harnesses were different between the different years of the turbo legacy but any diagrams you may have would be a big help.
Brad
Posted: Tue Feb 10, 2004 9:33 pm
http://www.surrealmirage.com/vrg3/ecupins/
Mods - Can we sticky this thread? I find myself posting this URL a lot.
Posted: Tue Feb 10, 2004 9:39 pm
by MY99 2.5GT
Thanks Main!
Posted: Tue Feb 10, 2004 9:41 pm
You're welcome.
Posted: Wed Mar 03, 2004 8:24 pm
by czo79
Anyone have any ideas as to whether it is possible to buy connectors that will fit into the ECU and ECU wiring harness? And if so where? I've thought about junkyards...looking at that it looks as if I could use NA ones, maybe have to add a pin or two. Basically so someone could make an ECU/harness extension, that would allow people to tap into the wiring harness without cutting up the stock harness?
I would like to make one of these....
Posted: Wed Mar 03, 2004 8:34 pm
by ciper
It exists for WRX's.
Posted: Wed Mar 03, 2004 8:37 pm
I have made these harness extensions just as you describe, Micum. I cannibalize an ECU for its connectors, and use pieces from a couple of harnesses (I filled all the pins, even the ones not listed in the pinouts, just in case).
I've done a lot of messing around with my ECU but haven't cut any of its wires yet.
Help ?
Posted: Thu Apr 22, 2004 1:53 pm
by LegacyUK
I need the same as Above an ecu pinout for a Legacy 2.0 Turbo 4x4 Saloon. Its a UK car
Anyhelp would be greatfully recieved.
Many Thanks
Alex
Posted: Thu Apr 22, 2004 2:39 pm
Posted: Fri Apr 23, 2004 3:22 am
by LegacyUK
OMG
Thank you soo much Josh you have no idea how long i have been looking for this
Many Thanks m8
Alex
Posted: Fri Apr 23, 2004 4:31 am
welcome....glad it's what you were lookin for
there are other scans and info on my site....it's more US spec'd stuff....but some is probably similar
https://main.experiencetherave.com/subaru_manual_scans
Posted: Thu Jun 02, 2005 7:03 pm
by Project_Legacy
hmm i am a little confused. so lets go into detail for a little bit. i am doing an ej22t conversion on my N/A...
so what i will be doing with the pinouts will be this?
1. change the B58.4 (crank angle sensor +) TO B58.5 (crank angle sensor-)
and...
2. change the B56.1 (cam angle sensor +) TO B56.2 (cam angle sensor -)
3. will this be all? what about the shields? since im changing from non-turbo to turbo. it shows the cam angle sensor shield for turbo (crank angle sensor for N/A) is B56.3 and the crank angle sensor shield for turbo (cam angle sensor for N/A) as B58.6 . do i switch those as well?
4. are those the only things i have to worry about for the ecu pinouts?
thanks for the help guys. im really lost, and since this is now a sticky, anyone else who is as lost as i am will be able to find this without asking about it again.
Posted: Thu Jun 02, 2005 11:53 pm
Posted: Fri Jun 03, 2005 7:54 am
by Project_Legacy
thanks for that. you're super helpful.
Posted: Tue Sep 27, 2005 5:50 pm
by azn2nr
josh, i cant find the pinouts on your site. do you have jdm ej20g pinouts 93-96 imprezza prefered
Posted: Wed Sep 28, 2005 4:25 am
Posted: Wed Sep 28, 2005 5:57 am
by azn2nr
V- you are the man. thankyou
Posted: Sat Mar 04, 2006 5:22 pm
by Psychoreo
ok yea....so i managed to screw up the wiring for my turbo swap and was wondering if anyone out there had the color of the wires to go along with the pinouts?
Posted: Sat Mar 04, 2006 6:15 pm
Check out the other stickies. In particular, this one, which includes a link to factory service manual scans which include wiring diagrams which include wire colors:
http://bbs.legacycentral.org/viewtopic.php?t=14485
Posted: Sun Mar 05, 2006 2:54 am
by danj
Wow, that is very valuable info thanks for bringing it up again. I needed all this stuff!! Thanks
Posted: Tue Oct 07, 2008 3:18 pm
by n2x4
Since Vikash's link is dead (I hope someone has all that stuff stored away)-
http://legacycentral.org/library/ECU_Landscape.htm
82 brat with ej22t SWAP!
Posted: Sun Nov 02, 2008 7:46 pm
by justin the subie
ok so some how im missing a wire or maybe something fried... a couple friends and i have been working on the wiring so not sure where we went wrong but the motor starts and sounds good but it wont idle and when i run a low rpm it runs rough... IAC valve? ive been tring to find pics and reading where it is or what it looks like so i can check it.... also read maybe a ground wire? searched for vac leak, tested many other things now im here asking and hoping someone can lend some great info...
motor ran and drove before i pulled it
Posted: Tue Jun 09, 2009 8:26 pm
My original chart is back up, hosted on Josh's server:
