STi 550's in Turbo rails - adaptor kit?
Posted: Sat Feb 13, 2010 12:15 am
I bought a set of '04 STi 550 yellow tops in prep for some kind of EM.
Question 1:
Has anyone used Carl Davey's adaptor kits to fit 550's to their EJ22T fuel rails?
http://www.carldavey.co.uk/product.php?id=2
Carl says that the adaptors work "if the grey top 440's are a direct fit the rail, then the adaptors will work"
I would like to do this so I could revert back to the stock 370 (or 390, or whatever they are) stock pink-top injectors later if need be. This would notbe possible if I swapped to the NA rails.
Question 2:
The 550's I bought do not have pintle caps on them. Do I need these...I expect that I DO need them (regardless if I use the adaptors or the NA rails).
I'll probably send these off to whichhunter for cleaning/flow.new o-rings, and he'll replace the caps too. Just looking for input.
Thanks,
Chad
Question 1:
Question 2:
Thanks,
Chad
