STi 550's in Turbo rails - adaptor kit?
farfrumwork
Post by farfrumwork »
I bought a set of '04 STi 550 yellow tops in prep for some kind of EM.
Question 1:
Has anyone used Carl Davey's adaptor kits to fit 550's to their EJ22T fuel rails?
http://www.carldavey.co.uk/product.php?id=2
Carl says that the adaptors work "if the grey top 440's are a direct fit the rail, then the adaptors will work"
I would like to do this so I could revert back to the stock 370 (or 390, or whatever they are) stock pink-top injectors later if need be. This would notbe possible if I swapped to the NA rails.
Question 2:
The 550's I bought do not have pintle caps on them. Do I need these...I expect that I DO need them (regardless if I use the adaptors or the NA rails).
I'll probably send these off to whichhunter for cleaning/flow.new o-rings, and he'll replace the caps too. Just looking for input.
Thanks,
Chad
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
kleinkid
Post by kleinkid »
Here is another set of adapters. You don't have to go to UK to get some.
http://www.deatschwerks.com/catalog/pro ... cts_id=194
Mine.
Perfect! Stock injector connectors won't work correct?
kleinkid
Post by kleinkid »
My stock ej22t injector conectors plug right on to the DW converted injectors. Not sure why they include the connecters. Maybe some applications don't.
BSOD2600
Post by BSOD2600 »
Ah interesting solution. Will keep in mind for upgrades if I ever get my car running properly.
With all my recent injector o-ring leaking issues, I wonder how much more prone this makes the whole setup to leaks...
'11 WRX Limited
'94 TW | R.I.P.
farfrumwork
Thanks all.
Klienkid, the DW kit looks like the same basic design as the UK kit, except it contains some unnecessary (for our application) connectors.
Did you use any other o-rings besides the 2 oem's on the new injector and the 3rd o-ring on the machined adaptor? (3 total per injector) No o-ring spacers like the 440 injectors need (?).
In the end it looks like either kit will work, and the UK kit is only $50.
The Carl Davey kit doesn't include the rail caps either. I don't believe those are needed, but I'm not sure. I got the kit, but I haven't installed it yet. The parts appear to be good quality, it has nice Viton o-rings.
Mattheww044
Post by Mattheww044 »
definately keep this thread updated on how it works. I don't really feel like getting 440's since I know I will be needing bigger injectors soon anyways. Thanks for the info/links!
