Car wont start / not charging
simpreza2
Post by simpreza2 »
My gf's car wont statr on its own. When jumped it starts ok. Before I left for school I replaced the alternator b/c it was bad and wouldnt charge the batt. I also bought a new DieHard batt. When she tried to starts the car it usually doesnt do anything(just the raido/lights come on) but sometimes it does click(as if the batt is on its way out) once. What should I have her or my brother check?
2006 Outback 2.5i 5 spd- 22k
1997 Legacy Outback 5 spd- 156k
1995 Legacy L Wagon 5 spd - 226K
BAC5.2
Post by BAC5.2 »
Starter?
scottzg
Post by scottzg »
starter wire, Battery terminal connections, and grounds. You have juice off the battery, but you have a poor connection somewhere that is preventing full starting power.
simpreza2
Post by simpreza2 »
BAC5.2 wrote:Starter?
I thought the same thing at 1st but if it can start on its own w/o push start I would think the started would be ok.
scottzg wrote:starter wire, Battery terminal connections, and grounds. You have juice off the battery, but you have a poor connection somewhere that is preventing full starting power.
Thanks, Ill have my brother check it out when he gets a chance.
Definitely sounds like a contact issue. Starters do get dead spots in them sometimes where they refuse to work when oriented in. I thought I had this problem last week and got a new starter in anticipation (it's the original), but I think all my short trips and below 0 cold just weakened the system as it's been fine since.
IronMonkeyL255
Post by IronMonkeyL255 »
On a completely somewhat unrelated note, I had that same problem a while ago (could hear the solenoid, but wouldn't start) and it went away when I uninstalled my security system.
Rio Red '91 Legacy SS
