Here's some pics. They turned out bad, I discovered that my new camera doesn't take close ups very well.
Any suggestions?
Ya, I'd rather not have to do that if I can avoid it.vrg3 wrote:Time and resources are limited so he's trying not do have to do that...
The ring (or lip) around the outside that would keep the belt from sliding off is kinda loose and bent all the way around. Or lopsided might be a better discription.I can't tell from the pictures -- is the entire sprocket bent, or is it just near that one part where it looks chewed up?
Ya, it's hard to see in the pics and I'm not sure what you were imaginingIt actually doesn't look nearly as bad as what I had been imagining. What do things look/feel like when you turn the motor by hand?
Maybe, I'll have to check that. You'd think it would be able to take better close ups.Maybe your camera has a "close-up" mode where it allows itself to adjust focus for very short range. It looks like in the fuzzy pictures the camera was trying to focus on the tarp.
Next time I get to go over and do some work I'll be sure to check it.vrg3 wrote:Hmm, okay, it looks a little more like I imagined now. Seeing the rear lip will help clarify things further.
Man, I don't know. *sigh* That's an extreme amount of additional work. If I have to do that I may as well just go about rebuilding my original engine. It's in better shape anyways. I don't really want to have to go through all this just to get the BJ (boostjunkie) engine in working order. I wanted to just drop it in to use while I rebuilt my original engine that has almost half the miles. The other thing is that once I do rebuild the original engine and want to swap it back in, I can't be having to pull all my parts back off the BJ engine. That's going to be a bitch and cause my car to be off the road again at that point, which isn't really feesable for me because it's my daily.It seems to me that if one were going to replace the sprocket it might make sense to replace the entire head, since that way you'll know the camshaft and its bearings are good.
