pcv system ideas
the o2 sensor managed to be hitting up against the tranny, and the wire split open and short circuited my SBF fuse. So I just unlpugged to the o2 and replaced the fuse.
Midas did a shitty job on the exhaust. So I am looking around for a new place, or ideas.
I will give that fluid test a shot!
95 Legacy N/A EJ22 - Turbo @ 5.5psi
WRX Turbo and Intercooler
STI Exhaust
STI Exhaust
it made no difference at all. I sprayed anywhere a hose went into a T or elbow or any type of connection. The car starts and idles but any rev causes it to go haywire. even after letting it idle for a bit it still begins to go nuts. Eventually the rpms drop so low the car turns off.
STI Exhaust
STI Exhaust
so I have no front o2 sensor, because its unlplugged, so would a bad rear o2 sensor cause this?
I just installed a air/fuel guage about a week ago, and it appears to read the rear o2 fine, but if I dont have a front one for now, and the rear one is bad then maybe my ecu is reading bad or nothing for exhaust flow.
STI Exhaust
STI Exhaust
You're using the stock 95 ECU, right? I have no idea how it would respond to having no front sensor and a bad rear sensor, or even no front sensor and no rear sensor.
But you could always try just unplugging the rear sensor.
yeah stock ecu, but the greddy emanage is intalled. And the car has had no front ecu for about a month now with no problems, but if the rear o2 went bad just now, then maybe....
Today I pulled my ngk densos and checked those, quite carbon fouled. I replaced them with nkgs 6s. My bov was leaking so I tightened that.
Turned the car on, it idles great, but I give it gas and boom it bogs, moves, bogs, then shut off. Sounds like a misfire or too much fuel maybe.
STI Exhaust
STI Exhaust
I checked all my settings, look good on the emanage (it has a warning light, if it blinks somethings wrong) but nothing at all.
So I checked all my wires again, and turned the car on. Idled almost perfect. Reved great, went for a ride around the block. I went about 40yrds, made it into 2nd then the car just bogged and turned off.
I am going to replace the fuel filter tmrrw. My egts were a little high, but nothing crazy.
STI Exhaust
STI Exhaust
In general new plugs are better than old ones. Which engine were the Denso plugs specified for?
Not being fouled and burnt after a month isn't a bad thing as far as I can tell, so I don't think it necessarily points to something being off.
I'm not a tuner, though, and your car is something of a Frankenstein setup, so I don't know what exactly you should be doing with spark plugs and spark control.
Okay... I'm not sure what you're asking, but if I were in your shoes I'd probably start with BKR6E-11 plugs and consider narrowing down the gap and/or switching to BKR7E-11 after some testing.
