Parking light switch able to turn on fogs??
Trailblazer
Can you put on aftermarket fog lights and have them turn off/on with the parking light switch on the column? I searched but didnt fins anything on this.
91' Legacy L Wagon w/93' 2.2 motor
http://members.cardomain.com/trailblazer24
Yes. I ran mine that way. Instead of tapping into the headlights, I used the parking lights.
Steve,
You did use a relay didn't you, and just used the parking light wiring to trigger the relay?
Of course. Sorry I wasn't clear. Yeah, if you don't use a relay you will melt switches.
Damn, I melted four on my '83 (Hella 550 kit came with a bad relay and I was too lazy to deal with wiring it - don't ask). One was even rated at 20 amps. When they failed, they melted in the closed position (of course as they'd only get hot while on). Luckily I never killed the battery or started a fire.
tris91ricer
- Title Whore
