fogged/yellowed headlight lenses
gustavohuber
Post by gustavohuber »
Hi there, so I've read some mentions of wiping out lenses that are fogged (like mine are), but after I popped off those little snap clips, the lens didn't seem to want to come off.. and I didn't want to force it.. any ideas?
Thanks!
/Gus
ex-devastated ex-owner of the $5500 parts car!
You shouldn't need to remove the lenses. The damage to the lens is typically just on the outside surface.
If you do want to remove the lens for whatever reason, though, you'll have to bake the headlamp to loosen the caulk attaching the lens to the housing.. Heat the oven up to 200 degrees, shut it off, and put the lamp in for maybe 10 or 15 minutes. Then slowly and gently wedge the lens away from the housing.
You clean the outside, not the inside, but i you wanted to take it apart, you can pop int in the oven for a few minutes on the lowest setting to soften the seal around the lens.
gustavohuber
wow, thanks guys! You posted at exactly the same time! Neat!
/Gus
tris91ricer
Title Whore
Post by tris91ricer »
Just in case you wanted it, here's the thread all about the de-yellowing..
http://bbs.legacycentral.org/viewtopic.php?t=739
I've found that not nearly so many steps are required. Just get yourself some #0000 Steel Wool and go at it with some kind of cleaner, or even water. Later, move to wax, and keep scrubbing 'til you get the results you want. You'll start to see the difference, and eventually, the lenses will *sparkle* again, and you'll know you're about done. Try using a combination of rounded and straight across strokes. I only spent about 10-20mins per light, and then shot 'em with a good douse of clear-coat, so the yellow won't come back. :wink: You'll see fine again...
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
J-MoNeY
Post by J-MoNeY »
91legacy_sleeper wrote: combination of rounded and straight across strokes
:lol:
98 LGT
gustavohuber
Thanks, Sleeper.. you live around SeaTac? I'll look for a badass legacy with pretty lamps next time I fly home :D
/G
tris91ricer
Title Whore
Don't look too hard for a "badass legacy" with pretty lamps, hehe, you WON'T find me. :D I have a nice-er grille, though.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
TurboSubie
Post by TurboSubie »
I just hit mine with a buffer and some minor compounds and they look like new:)
1994 Aegian Blue Subaru Legacy Sport Sedan. Mean Muggin.
1995 Honda CBR 600 F3 D&D complete system,K&N, few other things..
gustavohuber
actually wound up using WD-40 and a scotch-brite scrubber sponge.. good as new! I guess mine were "hazy" more than "rough"
I just want to note that pretty much all these methods will result in the yellowing coming back at some point. The clear coating is the only thing that will seal the plastic, and keep it from yellowing again.
tris91ricer
Title Whore
I clear coated mine, Josh, don't fret. :wink:
I even clearcoated the set I sold Jason, too.
The whole point of the project was to clean them off so you COULD clearcoat them, is the way I thought about it.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
gotcha....I thought you guys were just cleaning and not clear coating.
tris91ricer
Title Whore
The fumes are the best part, maaaaaan!!!
I think I ended up using an inferior clear coat, though.. if you look at the lenses from an angle, they look yellowed again, at least they do on my 92s.. The 91s sparkled after I did 'em up. I was so jealous, but I needed them to go.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
