AWIC vs WRX Intercooler
Ok, before I open a huge can of worms, lets check out the benifits and drawbacks of each.
I've got an AWIC and pump, still need the Rad.
I've got a line on a really cheap WRX intercooler
So the question is. Which should I go with
The AWIC has quite a bit of weight with it(liquid) and is electornically more complicated.
Then WRX is lighter but can get heatsoaked.
What are your opinions?
Frazer
Frazer
04 modified XT
99 LGT Limited
99 LGT Limited
You need to ask yourself, where do you mostly drive? Open highway, or in traffic.
Rather then hash over and over which is better period. You should ask yourself, which is better for my application?
I'm going with AWIC. Right now, the majority of my driving is in town. The electronics & complexity doesn't bother me. I will be sizing a pump and radiator myself....so those things don't bother me.
I had the same delema before I choose my current setup. The AWIC isn't a bad idea, but it is going to heat soak just as much as an A2AIC reguardless of where you drive it. As IIRC, water will absorb more heat then air. For the more interesting set up, go with the AWIC. It's not going to be any better. For a *little* less hassle on install, go with the WRX IC. Let me forwarn you that it's not just going to get slapped in there. You can check my thread out to see what I did.
Cliff notes: Go WRX.
98 LGT
If you size the radiator properly, the chances of heat soaking the AWIC becomes much much less.
you mean humor?
What do you need another fan for? The AWIC radiator is going to be infront of the Engine radiator.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
I can't recall if our fans suck the air in or push it though the radiator. I guess it would make more sense that they pull it. Back to the point! Umm, the radiator is just a big wall of heat. I would imagine that a little fan for the heater exchage would be a good idea, given that the radiator is going to prevent some suckage(blowage) of the fan's cooling capibilitys.
98 LGT
Our fans pull air through, that's the most effecient way to have a fan on a radiator (we'll depending on the size anyway). It doesn't come stock with a fan right? So why do you need to add another?
Okay, but that's obviously not a problem in stock form, which is still more power than our cars make.
Wo holly posts overnight, no wonder you three have over a thousand posts each Post whores :}
Your right I need to think of it as where I drive, I'm in traffic a fair bit of the time, but I live an hour outside the city in the country, so both apications work. What type of Radiator are you guys using for your awic setups.?
Frazer
Frazer
04 modified XT
99 LGT Limited
99 LGT Limited
I haven't gotten into sizing the radiator yet, so I really can't give you any info yet....
I've always wondered if you could use the stock AC condenser with some custom inlets and outlets made.snowjob wrote:Wo holly posts overnight, no wonder you three have over a thousand posts each Post whores :}
Frazer
98 LGT
You should be able to. Flow would be a little weird because the condensor is designed with refrigerant in mind, which enters it as a gas but leaves it as a liquid. And its fittings might be a bit small. I think it'd work pretty well anyway though. And it's already mounted securely in a great spot.
The fluid should be at fairly low pressure, so you ought to be able to get away with just cutting the fittings off the hard lines with a tubing cutter and then slipping heater/fuel hose over them, securing them with hose clamps.
if you did use the AC condensor, it would be imperative to use a positive displacement water pump, in other words a pump that can work against several PSI of back pressure. The smaller hoses that would be used to fit up with the small condenser would necessarily generate that back pressure, and you'd want to make sure your flow would hold up. The fluid velocity would be a lot higher in the small hoses to move the same amout of liquid, but that really shouldn't be a problem. If you think about how much water can come out of a 1/2" water pipe in your house, that's a lot of cooling capacity.
With the air mass flow and temperature, it would be pretty easy to do heat balances to figure out how much water you'd need to move ideally, then maybe double it to size the pump.
electric pump is what is normally used ???
I would use a heater core from a ford pick-up, it has the 3/4" inlet and outlet. Yukonart/Laurellthequeen are using a heater core from a GM application, for her AWIC setup. http://bbs.legacycentral.org/viewtopic.php?t=20158
I used the A/C condensor on mine, works great.
The stock system is not all that great in the pump and radiator. But it is still good for a lot more power than most of us have or will any time soon.
The AWIC won't heatsink at a stoplight like a TMIC. My IC stays cool to the touch all the time as long as the pump is running.
Low airflow with the Legacy SS hood scoop is another issue with the TMIC. On the other hand think of how much power a V2 STi makes with a small TMIC and not so big scoop.
Last thing: If you are not going with a bigger turbo or have plans for a lot of mods and HP, I would look into the Forester IC. Looks to be a much better fit and might not require a new coolant tank.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
93 Sport Sedan, 5mt
